Results 1 to 4 of 4
- May 2009
- 6
July 6th, 2012 09:46 PM #1It started after pinaayos ko mga kalampag. The next thing, namamatayan na siya mga 3-5mins after umandar. Aandar mamaya then mamatay uli. Had it checked, sparkplug full of oil. They replaced sparkplug, air filter and high tension wire. Cleaned fuel filter, tune up at change oil na rin. Thought all good na (after test drive, all good siya). The following day car starts, will run for 2-5mins then mamamatay. CEL light remains on, wont let me start the engine. A min or 2 na di nakasaksak susi, dun iistart. On my way to the mechanic, mamamatay then pahinga, start uli. 8-10 times mamamatay tapos start til I reach yung talyer. When I get there, ayaw na mamatay!
The next day inistart ko kotse, paiinitin ko, mamamatay tapos iistart ko lng uli. 30mins na puro ganun, then dinirive ko. Okay na... Parang kailangan mainitan muna sya parati para lng di mamatayan.
Di naman araw araw start ako ng start para mapainit kotse for half an hr para lng makaalis. Please help. Ano ba problema neto?
Thank you!
- Dec 2010
- 87
July 7th, 2012 02:56 AM #2better to start with trouble codes para malaman natin kung ano ang problema nyan. since umiilaw naman ang check engine light nya. for sure may DTC yan. ano ba yung huling ginawa jan sa kalapag? baka may tinamaang sensor o wire yan.
- May 2009
- 6
July 7th, 2012 08:47 AM #3Sir, yan ba yung ichecheck error thru computer box? Puro sa ilalim yung kalampag. Tinanggal mga gulong. Ang nakakapagtaka kasi, dapat mainitan para di na mamatay. Last prob ko dati, pag umuulan matagal mawala CEL lights pro after 15-20mins iistart na, pero di mamamatay. Ngayon magstastart agad pero mamamatay matay naman hanggang uminit.
- Jun 2010
- 321
July 7th, 2012 12:16 PM #4check mo main relay or fuel pump ......... or perform DIY check engine light diagnose DIY: Diagnose Check Engine Lights 4th gen Prelude - Honda-Tech
hindi ko maalala one of the youtube vlogs on 1GD
