Results 21 to 29 of 29
- Jan 2005
- 445
April 30th, 2010 09:48 AM #21Iba kasi ang paraan ng pag start sa carb at sa efi, Sa EFI just place it sa neutral then start. Sa carb kailangan mo prime ang carb bago ka mag saltik ng starter. pump the gas before hitting the starter.
April 30th, 2010 02:42 PM #22
yup sir, ganun din gawa ko kapag umaga. pump ko once yung accelerator, then start. ok naman. kapag nasa shade siya one click lang, pero kapag nabilad need ko ulit i-pump yung accelerator. pero nung minsan kasi puro crank lang, ayaw tumuloy magstart. wait ako a few minutes, then repeat the process. nag-start naman siya after several tries.
April 30th, 2010 03:59 PM #23
Depende rin mayroon mga carbed type na ayaw gasolinahan bago i start nalulunod agad gaya nitong 5k engine ko . Pag binomba mo gasolina bago start matagal bago umandar pero pag start mo na hindi ginagasolinahan andar agad siya.
May 4th, 2010 10:18 AM #24
good day!
guys, i got to experience this situation again last saturday. same thing, nabilad sa sobrang araw then nagstart tapos namatay, ayaw na magstart ulit. it was 1:00pm nung mga time na yun. tumawag me mech, he just said battery daw. i called another mech who arrived around 4:00pm. when he was about to check my engine, nag-start siya one-click lang! as in wala pang ginagalaw yung mech na dumating! nagtaka din yung mekaniko, wala kasi siya makita reason kung bakit ganun yung behavior.
then yesterday ibinyahe ko ulit yung car. i have no choice but to park it sa open parking ng mall, but this time nilagyan ko ng sunshield yung dash (the one na may silver coated lining). ewan ko kung may effect talaga, pero when i got back the interior was not hot as usual, then i started the engine. guess what? one-click lang! at hindi namatay!
could it be na may sensor ako sa dash na apektado ng sobrang init kaya namamatay yung makina ko?
May 4th, 2010 10:26 AM #25
sorry. double post...
- Apr 2010
- 71
May 4th, 2010 11:17 AM #26
This tip is really helpful garfield_08. Keep us posted if effective ang paglalagay ng sunshield everytime you parked directly sa araw. If it consistently starting in just 1 try kahit nakabilad pa sa araw, probably, the dash also got something to do with the problem pag nabibilad directly sa araw ang car at hinde sya dapat mainitan ng husto, am I right?
Since were also facing the same problem, if this "technique" is very accurate I might as well have to buy a sunshield and use it everytime Ill park in an open parking space.
May 4th, 2010 12:49 PM #27
*ms.pam: this is only an observation. whether it is a valid hypothesis or purely coincidence, i have'nt proven it yet. sabi kasi nung mekaniko ko baka daw naiinitan ng sobra yung sensor ng alarm ko (integrated kasi sa locks). he suggested having the alarm set-up trouble-shooted para makita kung may conflict (improper installation, overheated relays etc.) that would be posting problems sa electricals ko. as of now naging positive kasi yung effect nung sunshield. i'll try to test it several times and see if it works .
other than that, i'll also check for other factors na pwedeng mag-cause ng problema.
May 8th, 2010 01:44 PM #28
same experience here peeps... twice na. mine is Civic '97.. pagnabilad lang talaga... i was thingking then baka dahil sa E-10 gasoline ngayon. pero when i read this thread.. sa diesel din pala. baka nga there's something to do w/ hot dashboard... electronics. anyway, observe ko na rin.. kasi this time nilagyan ko na ng sunshield, dati kasi car cover lang (* village's open parking).
September 20th, 2010 03:06 PM #29
Sakin naman po ang nangyayari eh parang mamatay ang makina pag ka start ko ng engine then after ko mag shift sa D4 (A/t) ok na sya never pako experience ng namamatayan ako while driving yun nga lang parang pansin ko pag nabilad sa araw tsikot ko medyo mahina pag ka start and minsan naman po need ko pa 2 beses mag redondo para mag start siya pero after nung 2nd try ok na ulit yung engine... sa tingin ko po kasi sa init din ng araw kaya ganun ma try nga yung suggestion ni sir garfield EFI nga po pala engine nung sakin.
