Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
    #41
    sa akin, bumalik nanaman, sa umaga hard starting, mga 2 to 3 clicks but after nun, la na problem til the next day??
    Dec 2003
    #42
    Once in the morning, once after I had just parked my car, ngayon maayos nanaman, just for some more additional info I had just bought a new battery a month ago, ACDelco. I never had anyone clean the starter though.
    #43
    Tiny::: You hard starting failure could come from fuel lines. Not from batteries. Insufficient fuel along the line or an air leak within.
    KCboy::: Yung sa iyo, overloading ang problem. Sobra-sobra yung 8 Nautilus mo, di kaya supply ng current from your alternator and batt. Bawasan mo yung busina, say max of 2 horns? Babalik sa normal yan.
    #44
    mmmmm am also having start problem sa pajero ko
    pag start ang usok. then pag tumatakbo medyo mahina hatak?
    could it be glowplugs?
    Oct 2005
    #45
    its heater problem... just wait for the 2 (cliks) that you will heared from your engine and it will start... thank you!!
    Oct 2005
    #46
    dati din nag ganyan yung 4D56 ng Adventure ko.
    first di na nag 1 click sa umaga lang, then after a few weeks 2-3 start na lang sa umaga tpos pagpapatayin mo engine kahit mainit pa pagstart mo uli nag-2-3clicks uli.
    we then checked on the glow plugs (got that for 120petot each replacement lang)...ok naman nung una pag umaga lang nag2-3clicks sya...
    then after a few weeks bumalik yung dating kundisyon hirap i-start ng 1 click kahit init na makina!!! bukod pa jan bumabagsak menor nang madalang.
    we later found out na me leak yung hose na humihigop na fuel from the tank to the fuel filter...we replaced it and while in the process nakita ng dad ko na may butas yung mismong "fuel filter and pump", pinalitan namin yung fuel filter kanina lang(got it for only 750petot replesmemt lang mga kuya sa may masangkay the best offer we could find ;p) after namin fix, i-bleed and evrything,,,,,,,,,,,,,,,,,,,voila!!! one click uli si besprend!!! :D
    May 2005
    #47
    Quote Originally Posted by gudboy
    when cold start is hard malamang glow plugs, Mahinang batak try to clean your airfilter element if necessary replce na.Tune-up is also another factor.
hard starting
