i have existing glow plug na ang rating is 11V and noong bumili ako sa banawe OEM ang glow plug but the rating is 12V, may effect kaya ito kung sakali install ko sa makina? gaano kaya kabilis maginit ang 12V compare sa 11V? TIA
Hindi natin malalaman yan hanggan masubukan mo. Replacement plugs siguro ang binili mo. Napakaraming replacements lumalabas ngayon; ok naman yung iba, pero kadalasan hindi sila nagtatagal.
Sana kilala mo yung tindahan para masabi nila sayo kung ok ang produkto nila. May guarantee ba sila?
Buy the original glow plug according to your vehicle. Determine the original plug and buy the same rating and part number.
Doing other wise can be a waste of money or costly top overhaul.
sir, madalas naman ako bumili sa tindahan na napagbilan ko ng glow plug. actually may sample akong dala nung time na bumili ako. parehas ng size but different in rating lang. 11V ang existing at ang binigay sa akin ay 12V worry ko lang baka matagal mag init ang 12V compare sa 11V. sabi naman ng store owner pede ko ibalik kung hindi nagmatch. Thanks
You can individually measure the glow plug's resistance....., or apply 12 volts from a car battery. It should glow soon enough. Fast heat plugs will glow in 2 to 3 seconds. Old style plugs take longer to heat up. Don't apply voltage too long as this will damage the plug.
