Results 21 to 29 of 29
August 20th, 2003 09:21 PM #24Originally posted by ssaloon
ghost::: how much did it cost you and where ka nagpakabit?
Price? forgot na.
The main thing I like about nodalos is that they always do very good welding work as compared to Freemuff. Downside with nodalos, they have almost no stainless steel stuff so best to bring your own. The bigger CAT that I am using also came from nodalos.
August 20th, 2003 09:37 PM #25Originally posted by mazdamazda
ssaloon, i'll try to post it tom... kalkalin ko pa mga resibo..
i also suggest that you don't replace your pipings if that is your daily driver...
if you decide to get a larger diameter one, you'll experience some torque loss at low rpms, while you'll gain some hp at mid-high rpms...
August 21st, 2003 11:14 AM #26
i might go for CPM, pero i'll still wait for mazdamazda's recommended shop sa roosevelt.
- 370
August 22nd, 2003 09:01 AM #27OEM is the retail outlet of an OE supplier of exhaust systems.
It's across the Pepsi warehouse(?) along roosevelt.
It's a little difficult to find if you don't catch their sign(if they haven't changed it yet).
Having said that, if you haven't had you exhuast done yet, we offer the service now at our workshop.
Mandrel bent stainless steel is used exclusively.
TIG welded polished to a chrome like finish.
Other welding services also offered, Acy-Oxy, Arc & MIG.
- Aug 2003
- 107
August 22nd, 2003 07:38 PM #28auto_xer san b ung shop nyo? auto_xer question lang magkano kay aabutin pag nagpakabit ako ng full exhaust system sa revo ko with gasoline engine? magkakaroon ba ako ng problema pag nagpakabit ako nito or in short what is the pros and cons nito. tnx hope you will help me with this problem...
godbless
- 370
August 24th, 2003 06:21 PM #29jevy0712,
Have to measure the amount of material you exhaust system is going to use to quote a price.
1328 e.rodriguez between t.morato & balete drive, besied Bilyar.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
