Results 1 to 17 of 17
    How often do you use fuel system cleaner for diesel engines? What brand ba ang maganda and mura? I do it every 5k lang, is this enough? Comments please!!
    Jan 1970
    is STP considered as fuel system cleaner.. i have tried it once yung kulay light blue .. sabi nung label consumes less fuel daw and cleans injector .. pero hindi ko naman na feel yun kasi the same pa rin ang consumption ng fuel ko.. about sa injector.. maybe who knows.. paano ba malaman na clean ang injector?
    All diesel fuel as I have read from the oil manufacturer's site do contain detergents and dispersants which qualify as fuel system cleaners. So all of them has it in some form or another so pwedeng di ka na gumamit. Ako I use Mitsu Diesel Fuel system cleaner every 5k just to be safe. :mrgreen:
    ako I use CarbonClean :wink: (shameless plug)
    http://betancalibration.com/services.htm
    Doc Diesel
    hmmm.. machine pala yung carbonclean... heehehh . magkano kaya yung service na yan?
    Quote Originally Posted by HBOY
    depends on the engine size...
    Doc Diesel
    Doc Diesel,
    Since you are an expert with regards to Diesel Engines.
    Is it really safe to say that Carbon Clean really works? I have been to their shop in E. Rodriguez to have our trucks quoted and they say na once you have your diesel engine carbon cleaned, di na kailangan ng calibration.
    Comments please. Thanks...
    Quote Originally Posted by lancelot
    Doc Diesel,
    There are several factors to consider before using CarbonClean and or doing a calibration.
    Though we still assess / inspect the engine prior to dong any work. What we do now is to offer first the CarbonClean before going into calibration. You see, CarbonClean and calibration has one thing in common, that is to take out the smoke.
    CarbonClean cleans out the dirt, gum, varnish and carbon build up your engine has built up over the years. Though this system passes through your fuel system, it's not an assurance that your pump and injectors will be squeaky clean. Nothing still beats disassembling the fuel system and overhauling it.
    It's main target is the carbon in the engine, second only is to clean the fuel system.
    I have tried this on my 2.5 yr. old Mitsu. Adventure and a friend's Isuzu Highlander. It does work but you have to consider how old the vehicle / engine is. The older the engine gets, the more carbon. The more carbon, the more CarbonClean detergent we recommend to use.
    hope this helps.
    Doc Diesel
    Doc Diesel,
    Do you also do carbon clean services in your shop?
    I had my 1996 pajero diagnosed as well as our trucks, sabi kasi ng shop sa e.rod kuha daw sa carbon clean since we do regular maintenance evry 3 months naman.
    Thanks so much for your advice
    Doc Diesel,
    lancelot,
    yes, we do have CarbonClean service in our shop. We can even come to you for fleet servicing. Call our makati office at 8992819 and look for my bro. Dave or James.
    Doc Diesel
    Jan 1970
    draining the fuel tank once in a while would help too in reducing dirt and water build up in the systemsince some diesels are really dirty and contaminated with water.
    hmm.. boss doc!... sayang nde ko nalaman about this carbon clean when i visited the makati shop about a leak in one of my injectors....
    my engine is a 1979 3.0L MB diesel engine.... when you say more detergent.. this means one treatment but stronger? o multiple treatment in phases?
    One treatment with literally more detergent to consume. You see, when we treat your engine for CarbonClean, the detergent is placed in a container within the machine which will be connected to your fuel input and output or return. More detergent would mean longer running period. For example:
    8 oz. of detergent would be consumed in more or less an hour. The more detergent, the longer engine running period. Take note ha, that we need to run your engine while it consumes the solution.
    You might wonder, 8 oz. lang? or Bakit ounce ang measurement? A bottle for diesel detergent which is 16oz. is already strong in a sense that it can knock you down.
    Doc Diesel
    ahh...ganun ba? lakas pala nung detergent na yun.. tawag na lang ako sa shop nyo to inquire about the price.. tnx.... tagal pala 1 hour.hmm.. is that one hour under a load? o idle?
    while idling yun HBOY.
    Dec 2002
    Doc Diesel,
    Where or how do you connect the carbon clean machine on the fuel system?
    What effect would your detergent have on the additives/detergents in the engine oil?
    Quote Originally Posted by jackaroo
    Doc Diesel,
    for Diesel: going in through the fuel filter or injection pump inlet then out to the return line from the injection pump.
    for gasoline: going in through the carburetor / fuel pump then out to the return line of the carburetor or the aluminum manifold for fuel injected.
    Doc Diesel
Fuel system cleaner - how Often?
