Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Oct 2008
    Mga experts, balak ko po kasi ipa-convert yung fuel pump ko in Universal Fuel Pump! Meaning, ilalabas o ililipat na yung fuel pump ko sa hood near fuel filter. Kasi, nag-loloko yung fuel pump ko, pag umiinit na, pumuputok na yung fuse na Cause is tirik! Suggest sakin ng electrician ko, i-convert nalang at mas mura pa talaga. Cost lang ng mga 1.5k convertion including Brand New universal pump motor. Too expensive po kasi yung electronic fuel pump, nasa 6k brandnew!! My disadvatages kaya ganun?? Pero, my nakapag try na po sa inyo ng ganun? mr ride is Sentra ECCS.
    Hanap ka na lang surplus in Banawe, Nissan marami yan mga 1.5 lang yan
    Buy ka nalang ng oem pump or kung nagtitipid surplus nalang pero you'll never know when a surplus unit will break down. Most of the fuel injected cars have their pumps/filters near the gas tank except for those mechanical type. Could be for safety purposes. Frankly, I would mess around with the fuel system.
    Oct 2008
    medyo hindi kasi sigurado sa mga surplus na fuel pump, baka after 6 to 8 months, mag loko ulit! yung universal fuel pump, nasa 1k lang brand new, but hindi ko lalam kung my disadvantages yung pag coconvert!?! baka bumagal kasi hatak!
    kung marunong yung mekanik sa conversion walang prublema yan , tanungin mo muna siya kung kaya .
    Aug 2004
    Quote Originally Posted by joseph20 View Post
    Hmm....there's are reasons why the original pump was placed inside the tank... it's also easier to push liquids than to "pull"........
    The pump is also cooled by the fuel.
    It takes more work to pull out and replace the old pump and your mechanic is not comfortable with the job so he recommends the conversion.
    I don't trust the P1.5k elec pumps...I've gone through a couple of them.
    You'll be lucky to find one that will serve you for many years...
    If I were you, I'd invest in a new or relatively new pump same as your old one.... expensive maybe but for safety and convenience, it's worth it.
    Agree ako kay Eric, pumps are cooled by the fuel. Its also better to push than pull. The down side of putting an external pump is the noise it creates and the difference in rating.
    If your present pump is working and the fuse gets busted then wiring, grounding or stuck-up ang kailangan tutukan.
    you need to use a high-pressure fuel pump coz your ride is EFI ... AFAIK, those 1.5K-fuel pumps are low pressured ... correct me if I'm wrong ...
    Oct 2008
    I said to the electrician that, baka wirings lang at may problema sa fuse box or grounded. But, he test kung may grounds, kiniskis nya, but wala naman ka spark spark, also he checks the fuse box, wala rin naman daw problema. He explain na, my case daw sa mga fuel pump na pag sobrang init na ng motor ay pumuputok na yung fuse ng fuel pump, and ang suggestion nya is convert it to universal pump, ilalagay nalang daw sa tabi ng fuel filter under the hood. Naiisip ko lang kasi, bakit ang mura ng universal electronic pump, nasa 1k lang siya, yung brand new na electronic na OEM nasa 6k to 8k sa Casa. Kaya I ask here baka my side effects or delikado o baka naman bumagal hatak. Marunong at may mga na-convert na naman daw siya like vans, kia, and a civic.
    newbie po kasi ako sa mga ganun.
    Jan 2009
    I wouldn't change the design of the car, especially when we're talking about fuel systems. The fuse is blowing for a reason and the mechanic's analysis seems correct. What I disagree on is the workaround he's trying to sell. I'd rather change the fuel pump with the same OEM pump. Less alterations means the car remains stock-safe.
    Oct 2008
    pero, tama po kaya analysis ng electrician ko na fuel pump problem talaga yungpag putok ng fuse ng fuel pump?
    procedure dyan ganito;
    paandarin yung sasakyan at gumamit ng bypass feed wire ( it must be fused with the right rating )
    kung nag blow yung fuse -fuel pump ang sira
    mas maganda kung meron digital amp gauge para precise ang reading.
    kung hindi pumutok yung fuse, intermittent ang sira ,possible wire problem
    rewire na lang yan.
    Jan 2009
    The electric motor in these fuel pumps do wear out eventually. My take on this is that the carbon brush "dust" may have filled up the gaps between the commutator, causing it to short and tick-off the fuse.
    Oct 2008
    meaning po ba dun? talagang Fuel pump na yung may sira or diperensya?? Pwede kaya fuse box po ang may diperensya??
    Jan 2009
    Malabong fuse box ang problem. Best approach dito ay kung may access ka sa shop manual ng car mo, i-check yung impedance/resistance nung fuel pump motor kung within spec pa.
    Oct 2008
    Thanks sir for the info, grabe kasi price ng brand new Fuel Pump, 7.5k!?! Siguro, ipa- convert ko nalang muna, hindi naman daw babaga; hatak ng kotse, parang ganun pa rin naman daw yun. Yung nga lang, nasa hood na siya!
    Be sure to use the existing wiring of your fuel pump and not to just tap in in the ignition. It is not suppose to be permanently turned on when you switch the ignition.
    guess ko lang parang hindi well versed yung gagawa nito ,
    to make the fuel pump working properly , it must be installed under the car railing ( chassis) and not only that , the tank has to have a lift pump built -in in order to initialize the fuel delivery into the main pump.
    the negative effect of installing it above the tank level is great, the guy must consider that .
    Oct 2008
    Sabi sakin sir mechanic na, mha hose lang daw po yung gagalawin to convert it, kasi pag surplus na Fuel Pump, nasa 1.5k surplus, at hindi kas sure kung kelan ito ma broken or magmalfunction, the new Universal pump cost only 800 pesos. . Pero, as you said nga, parang delikado yung pag coconvert?! What is the best way option? my problem is the bdget for new Fuel pump that cost 8k!
    san ka nag tanung ng fuel pump? try mo dito 6473746 Nisway si Bong hanapin mo, baka makakuha ka ng discount. or baka may replacement pump at least nasa same location yan. IMO, hindi parang nag convert ka ng windshield washer/reservoir ang pag convert ng fuel pump. There are also safety issues here.
Fuel Pump Conversion
