Results 11 to 17 of 17
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 5th, 2008 10:21 AM #12
May 5th, 2008 08:54 PM #13
What we usually do to check fuel delivery problems is temporarily replace rubber fuel lines with transparent hoses so we can see if there is pumping activity or air cavitation. Before assuming its the pump or the ECU I suggest you do his simple test.
*burjegol> Carburator type fuel system uses mechanical and sometimes electric pumps to transfer fuel from tank to filters to carb. Vacuum alone will not be enough unless the tank is level with the carb.Last edited by 4JGtootsie; May 5th, 2008 at 08:59 PM.
- May 2008
- 4
May 16th, 2008 09:13 PM #14Hi guys! Any idea how much is the fuel pump replacement for a 2000 Honda City Type Z? Saan kaya nakakabili nito na mura? Banawe or Evangelista? TIA!
- Nov 2003
- 3,849
May 22nd, 2008 08:38 AM #15electronic fuel pumps should be around 2-3k and a couple of hundred bucks for the labor depending on how hard it is to get to the pump.
October 10th, 2009 10:46 PM #16
i own a honda city idsi 03, ayaw na magstart ng engine, pero ok naman yung battery, fuel pump problem daw sabi ng mekaniko sa kanto, pero dinala ko na sa casa to be safe....pero magkano kaya ang fue pump, and what causes its malfunctioning?
- Oct 2005
- 64
October 12th, 2009 10:54 AM #17
if you don't hear the 3 seconds hum when you put the key on start (not ignition) then your pump is busted. But if you can still hear it have it checked using a pressure guage. Usually nasa above dapat 35PSI yung reading. pag mababa na pressure palit na.
ang cause ng premature wear/malfunction ng pump is when you dont regularly change your fuel filter and allow less than 1/4 of fuel sa gastank.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
