Results 1 to 5 of 5
April 22nd, 2009 07:54 AM #1
Guys, was wonderin' if any of you can help me out. I found out yesterday that the fuel neck of my 94 Lancer has a hole and upon closer scrutiny, I saw that the metal's rusted badly so I need to have it replaced. By the way, the fuel neck that I'm talking about is the snake-like tube that connects the fuel tank to the fuel "nozzle" i.e. where gas gets pumped in.
Maybe some of you know shops in Banawe that sell these things? TIA.
April 22nd, 2009 09:48 AM #2
kaya mo kalasin. di ko alam kung yung nakita kong stock sa store e para dyan sa fuel neck or para sa engine. but i am sure its for a lancer.
April 22nd, 2009 04:19 PM #3
nicolodeon,
the corossion on the filler neck is an easy fix if you have a tube of a two part epoxy based repair kit. it is about 5/8 inch in diameter, about 4 inches long, you knead a portion that you need and stick it to the part where the leak is coming from. the material is unaffected by gasoline, jp 8 aviation fuel, diesel and other petroleum products. it is workable in 10 minutes and ready for service or cures as you install it back.
jick
ase certified master automobile technician
ase certified master heavy duty truck technician
April 22nd, 2009 05:55 PM #4
April 22nd, 2009 06:32 PM #5
If that's the gasoline filler metal pipe, you will be smelling the gasoline fumes inside your cabin as Lancer 94 rear compartment and the cabin area is only covered with rear seats.
You have 3 options:
1. you can just have it repaired at a welding shop. They will remove the pipe tubing out of the car and do acetylene job on affected portion.
2. or if you want the whole thing replaced, you can go to muffler assembler that has pipe bender to fabricate it for you.
3. you look for OEM replacement.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
