Results 1 to 6 of 6
July 31st, 2007 10:29 AM #1
i've been having some leaks on my 240d's fuel injector for quite some time now. the leak seems to come from the bottom of the block itself. the amount of leaking fuel seems insignificant say 1 or 2 drops per minute when the engine is running. problema is, the drops find their way onto the engine support. kaya i have to clean the engine support and its surrounding with soap and water from time to time or else my engine support is toast.
i'm thinking a new set of gaskets will fix this. anybody have an idea how much this will cost me? thanks!
July 31st, 2007 11:00 AM #2
yun engine ko na 4d56 nagleak ang injection pump inabot ako ng 1k kasama na baklas tsaka kabit....
July 31st, 2007 11:18 AM #3
saan ka nagpagawa ser? palit lang ng gaskets yan ser or may ibang parts ka pa? balak ko ipaayos this weekend eh. salamat!
July 31st, 2007 04:02 PM #4
Pwedeng fittings lang yan. Check also return pipe.
But if you think you are due for injector cleaning, solve na lahat yan including the washers.
July 31st, 2007 04:16 PM #5
Injector pump is non existent.
July 31st, 2007 04:27 PM #6
Pag sa injection pump ang leak pwedeng delivery valve ang problema. I almost lost my last trooper because of that leak. Nababad ng diesel fuel yung mga wires sa ilalim ng leak then uminit tapos lumiyab. Happy happy pa ako sa loob tapos may naamoy na akong sunog. Buti may fire extinguisher ako kung hindi goodbye na!
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
