Results 11 to 14 of 14
- Jan 2007
- 7
February 5th, 2007 11:27 AM #11I had the same problem before. Pagka-install ng indiglo ko, ayaw naman gumana ng fuel gauge. As in umilaw na yung "red fuel icon" to indicate na wala na ako fuel, saka ko lang nalaman na sira gauge ko.
Binalik ko dun sa pinag-installan. Masyado lang pala nadiinan yung pagbalik nung needle. So, tinanggal nila yung needle, then dahan-dahan binalik hanggang "ma-feel" (I'm not sure about this) daw nila yung "tension" ng needle.
Ok na sya ngayon. Baka nadiinan lang. To be safe, balik mo sa pinagpa-installan mo. Or kung malakas loob mo, baklasin mo yung gauge cluster, dahan-dahanin mo i-pull yung needle. Kasi sa GSR, nung binaklas uli nila yung gauge cluster ko, pinull lang ng konti, then nung pag-start ko ay pumunta sa tamang reading yung fuel gauge.
- Jul 2006
- 52
February 5th, 2007 04:23 PM #12try ko gawin or hanap ako ibang shop dito..pampanga pa ako and sa makati pa un...layo layo =(
tnx sa mga reply mga bossing..
kung me ma issugest pa mga iba dyan..tia! =D
February 5th, 2007 06:05 PM #14
Just sharing a similar problem which occured after replacing the bulbs in the panel. Maybe some of you have read my thread in the Goods Squad section.
Anyway, I had the fuel gauge assembly replaced. After nun akala ko ok na. By that time mga 3/4 pa laman na gas. Everything seems to be ok (gauge is normal) until I had a full tank. After nun erratic na naman ung gauge especially when I make turns. I'm thinking pag dating nya ng 3/4 ulit baka bumalik sa normal (hopefully). Might be the floater this time. Ewan ko ba.
This all started with replacing the bulbs in the panel. Umiilaw pa naman un nga lang medyo madilim na. Sana hindi ko na lang pinagalaw...
Daming issue ng SU7:grin:
Xiaomi E-Car
