Results 11 to 16 of 16
January 16th, 2019 04:55 PM #11
^ baka na stuck iyong gas tank fuel level float.
There's Only one way to be sure - just have it checked.
do what you gotta do so you can do what you wanna doLast edited by baludoy; January 16th, 2019 at 04:58 PM.
January 16th, 2019 09:49 PM #12
Maybe you achieved a very high fuel economy during the trip. 60km will only cost you maybe about 3 liters or so of fuel (around 20km/L) driving a Mirage at continuous highway speeds.
- 52,729
January 16th, 2019 11:44 PM #13i don't mirage, but
if you filled it to the brim of the filler tube, or beyond your tank's capacity, it may take some driving, for the fuel tank float / sensor, to float down low enough so as to make a difference in your fuel gauge.
you over-filled, po, and you will have to use up more fuel for the gauge to move.
start worrying, if you had already driven 200 km and the gauge hasn't moved, yet.
- Nov 2014
- 454
January 17th, 2019 12:27 AM #14
- 52,729
January 17th, 2019 12:39 AM #15when filling to overflow at the brim, that's, to my very rough estimate, about 2-3 liters of fuel over the fuel tank's maximum load, depending on each car model's length and diameter of filler tube.
the engine has to consume those 2-3 liters, before that fuel level sensor can notice a difference.
at 15-20 km/li, that's up to 60 km of travel, before the gauge can begin registering any change in fuel level.
also, there's the sensitivity of the fuel gauge to changes in fuel level.
i like the old analog, needle fuel gauges. even small changes in fuel level may be seen.
some of today's digital fuel gauges show bars only.
in my wigo, a bar is about 2.5-3.0 liters or 25-30 km worth of travel. i have to travel 25-30 km, before a bar disappears.
in some cars, there is the "km range" read-out. i don't use it, as it only confuses me.
heh heh.Last edited by dr. d; January 17th, 2019 at 12:47 AM.
- 52,729
January 26th, 2019 12:58 AM #16i have problem.
i had my 2005 D4d innova's aircons cleaned, both rear and front.
the dash instruments were necessarily pulled out, the electrical connections pulled off.
my rear connections to the fuel gauge sending unit were also detached.
when the mechanics put everything back together, my gas gauge needle didn't go up to the before-detaching level.
in fact, the needle seemed to be registering much less than what i am used to. even when i filled up with fuel, the readings are significantly less than what i used to expect these last 13 years.
everything else was fine.
any ideas on how i can get my old needle readings back?
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
