Results 1 to 10 of 10
- Aug 2003
- 9,720
May 27th, 2007 04:40 PM #1peeps, been thinking about having my carb checked out and possibly cleaned out. un kasi ang suspect ko for the low fuel mileage i've been getting.
nasa 7km/L lang nakukuha ko(my ride is an '89 1.3L corolla XL)...but i've read a lot of posts na malaki ang chance that things might get a lot worse once the carb gets fiddled with.
i'm planning to take my ride to any one of the carb shops along kamuning -- dun a A&M in particular. ok ba dun?Last edited by badkuk; May 27th, 2007 at 05:22 PM.
May 27th, 2007 05:05 PM #2
When I still had my 96' XE, my city consumption was 9-10 km/li.
:toma: [SIZE="2"]2959[/SIZE]
May 27th, 2007 05:22 PM #3
Ok naman sa a&m, look for mando. sa kanaya ako lagi pumupunta pag may problem ang car ko.
however, look at the condition of your spark plugs first. how does it look like? maiitim ba, full of soot?
May 27th, 2007 06:17 PM #4
baka need lang muna ng tune up yan (plugs, contact point, condenser, timing, air cleaner, etc) . pag lagi ka sa traffic talagang ganyan ang consumption niyan. Air/fuel mixture sa carb also contributes to a high fuel consumption.
September 2nd, 2007 09:07 AM #5
can a 1999/2000 Honda civic vtec vti with a kilometer reading of 175K+, casa-maintained, still has a chance to improve its fuel mileage/efficiency? if so, what should be done? thanks
September 2nd, 2007 09:28 AM #6
What is your current FC and driving habits?
Driving habits has a big factor in your FC.
September 2nd, 2007 09:59 AM #7
well, driving at 40-60kph in city; averaging 80-100kph in hiway (slex/STAR hiway). no so-called jack-rabbit starts
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 2nd, 2007 10:05 PM #8What milage are you currently getting?
Best way is to maintain your car properly. If you need to change the oil and get a tune up. And keep your air filter clean. Try to drive with a light foot and coast as much as you can. By coast I mean car in gear, not neutral, foot of the gas pedal and ready to apply gas or brake as needed. Best done downhill.
Another thing is you can use energy conserving oil. Havoline Energy is a good example. But dont use those gas saving devices.
- Aug 2007
- 246
September 5th, 2007 03:31 AM #9regualr maintenance is a big help pra constant FC. ako i try not to rev over 4k kng hindi kelngn. learning to coast has also made a big difference din. (leadfooted kse ako dati e ). try to maintain ur recommended tire pressure as well.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
