Results 1 to 14 of 14
    Feb 2007
    gurus, any comment on this sanyo fuel saver? this device is sold here in davao city for 3,5t. point A is a container for kersone going to point B, the device itself. point C is where the hose ends. id like to validate this device here before having one. this pic is taken from a friend's car who swears it really saves fuel and increases engine power. thanks
    i can't see the logic, adding additional fuel (kerosene) to the intake to save on fuel? the device looks like a simple atomizer (mixer) to dilute the kerosene to be mixed with the intake air.
    they simply dont work and are pure marketing hype IMO.
    Sep 2004
    S-C-A-M.
    And to top it off, if this isn't related to the electronics firm Sanyo Electric Co. Ltd., the manufacturers of this device should be sued for illegal use of the trade name 'Sanyo'.
    Looks like an off-shoot of the air-bleed system being sold as the Khaos Super Turbo Charger. The gimmick here is the kerosene vapors that supposed to help increase your fuel millage. Personally the amount of kerosene vapors will not make a difference. (This sounds like mixing kerosene in their fuel to help increase millage.)
    You should ask your friend to have his diesel engine checked if it needs to be tuned up. You can ask him to do a test by running the engine with the bottle but with no kerosene. Another test with the entire system plugged off.
    Aug 2006
    scam.
    best fuel saving tip: use the bus.
    Quote Originally Posted by snowbound View Post
    useless
    best fuel saving tips:turn off engine in heavy traffic
    roll down windows during cool days or nights
    walk on short distance trips
    remove excess car luggage
    Sep 2005
    Not again?
    Another scam.
    Aug 2007
    From the looks of it, it looks like it would really save you on diesel...
    But you'll have to spend on the kerosene. Isn't kerosene more expensive than diesel nowadays?
    The principle I see here is from the rumors that gas stations used to mix kerosene with diesel to make the blend cheaper. But now that kerosene is more expensive, it defeats the purpose.
    nope it will not save u anything and it may harm ur engine.its purely marketing hype.
    Aug 2007
    Sanyo... sounds a lot like the SANJO Fuel Saver, another Khaos clone.
    kakatawa yung pagkasulat ng mga flyers ng product na yun
    Feb 2006
    kerosene? di ba masama sa engine yun?!
    Feb 2007
    Quote Originally Posted by recklus View Post
    kerosene is mainly used in fuel for jet engines (more technically Avtur, Jet-A, Jet-A1, Jet-B, JP-4, JP-5, JP-7 or JP-8). One form of the fuel known as RP-1 is burned with liquid oxygen as rocket fuel. Kerosene is sometimes used as an additive in diesel fuel to prevent gelling or waxing in cold temperatures.
sanyo fuel saver
