Results 11 to 16 of 16
February 4th, 2006 06:58 PM #11Originally Posted by v22
kung maingay as in the engine is louder than the usual crackling sound, have the clearance checked. 109th mileage, pwede mo patignan. di naman magagalaw unless adjust nila. feeler guage ang gagamitin para malaman ang clearance. dont worry. di masisira iyan basta marunong ang gumagawa. mas fuel efficient ang properly adjusted valce clearance and di gaanong mausok.
February 4th, 2006 07:04 PM #12Originally Posted by finchy18
spark plugs replace
clean or replace air filter
fuel around 30th km
clean throttle body around 20th km (carb. efi=depending sa environment and sa pms mo)
check timing (carb. efi =for those where the timing can be adjusted)
valve adjustment depende rin sa vehicle. some have self adjusting. some are shim types which cannot be adjusted
Toyota is my choice
- Aug 2005
- 2,063
February 4th, 2006 11:32 PM #14Originally Posted by banaweonline
about dis valve adujstment and clearance for my corolla carb sir simple tuned up lng ba and adujstments?
- Mar 2006
- 11
March 11th, 2006 05:09 PM #16Originally Posted by banaweonline
And also,any qoutation sa replacement ng pressure plate,clutch disc,released and pilot bearing for 2L engine transmission, Toyota Hi-Ace commuter van.
Saan po pala banda ang shop nyo...kung kaya ko qoutation nyo sa inyo ko papagawa.
Thanks
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
