Results 21 to 30 of 32
April 15th, 2006 02:23 AM #21Originally Posted by spearhead_970
Toyota is my choice
- Aug 2005
- 2,063
April 15th, 2006 10:09 AM #22caltex gold techron and petron XCS try mo pa aboting ng ilaw yun Empty tank tapos mag full tank kna or 200 petot
- Oct 2004
- 45
April 18th, 2006 03:54 AM #23Mazda 323 /93 has no contact point it's already electronic ignition. Anyway, thank you guys, I'll try all your technical knowledge.
April 18th, 2006 10:45 AM #24Originally Posted by afrasay
try this one sir, Have a major tune up. Adjust tappets then that tok sounds will go away....
- Jun 2005
- 153
April 18th, 2006 11:30 AM #25isa pang advice, nangyari sa akin yan l300 gas engine, kapag 3rd gear, makakarinig ka ng ping sound, takatak.. pag 1st and 2nd gear wala ka maririnig, napansin ko, it happens kapag gumigitna na ang temperature, so pinacheck ko, overheating. yun ang ang pinasolve ko, nung almost 1/4 na ang temperature, nawala ang ping sound, (tak-tak-tak) so itoy naexperience ko lang na nasolve, pwede rin iba ang nag cacause nito.
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 19th, 2006 12:51 AM #26hotter engine temp will result in an engine more prone to detonation. kaya run it as cool as possible.
Toyota is my choice
- Aug 2005
- 2,063
Tsikot Member Rank 4
- Jan 2007
- 2,326
June 8th, 2007 04:13 AM #28
June 8th, 2007 04:34 AM #29
June 8th, 2007 08:12 AM #30
na mention mo na kahit sa hway meron ka naririnig, you have to fix that. pinging sound indicates that the fuel is being burned way before the piston reaches its top cycle. it will lead to overheating of the cylinder head and cause other kinds of problems you dont want to have.
kung nasa timing naman ang makina mo, you can check on the carb if its carb type, and have it tuned up (look at the spark plug, air filter, fuel filter and as they suggested contact point kung meron ang dizzy mo) also have the valve clearance inspected kung within specs pa.
using higher octane fuel may help as stop gap measure.
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
