Do all engines rotate in a certain direction? Facing the crankshaft pulley/harmonic balancer, I know my car's engine rotation is clockwise, because I once had to do a valve adjustment on it so I had to know which direction to turn the engine
Curious if others have it turn the other way. And what would happen if you turn it the wrong way (in general)? I'm sure the timing won't be off but it might if the belt and sprockets slip a tooth due to release of tension (if it's not tight)...aside from that?
