Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Guys kelangan ko na kasi palitan engine support nung sir ko eh pinag iisapan ko ngaun kung papalitan ko sya ng original engine support which cost like 1k+ each or mag pa insulate nalang ako ng engine support mga 300-400 lang ata ganto! anu ba sa tingin nyo mas better choice kasi ung insulate daw matibay nga kaso matigas daw ata masyado kaya magiging ma-vibrate! TIA
    i'd rather go for oem, para less vibration.
    sayang naman kung replacement lang, go oem.
    Aug 2003
    oem nalang pare.
    Oct 2003
    i was in your situation before. i chose the replacement. in the end, oem parin ang bagsak ko.
    Dec 2002
    better go for original or your other engine supports may get damaged because of the new harder rubber from one of the support. And definitely the engine vibration will be flet more.
    Sep 2006
    OEM. Kaunti lang naman ang difference (I mean, hindi pa naman sayad ng libo ang diperensya). Nothing beats the original (in most cases).
    Aug 2003
    advisable po bang magpa fabricate ng engine mounts? pagkasabi sa kin nung nagpagawa ako, mas matibay daw siya, pero mas nagvivibrate.
    baka yan yun sa paakyat ng antipolo, ma vibration nga yan.
    mamar,
    how old is your sir?
    Quote Originally Posted by afrasay View Post
    mamar,
    well Its not really an sir its a 96 vti converted to sir, 10yrs na ung oto chineck ko kasi kahapon halos lahat ng supposrt crack na yung isa hati na talaga sa gitna!
    Apr 2006
    ilan ang engine support??
    go orig!!!
    Quote Originally Posted by Kikkomann View Post
    Uumm.. i need to replace 3 engine supports so lets say 1200 each ang oem so 3600 nayun eh pag insulate naman kung 400 isa edi mga 1200 lang lahat lahat!
    sa OEM ka na, 1200 sa una, after ilang months 1200 ulit tapos 1200 ulit tapos 1200 ulit tapos 1200 ulit........ hehehe. kaya bili ka na lang ng orig, isang bagsak na 3600 lang.
    May 2005
    Quote Originally Posted by fLaKeZ View Post
    Di ko alam kung tama, pero sabi sakin nung mechanic ko dati, pag isa lang sa mga sira ang pinalitan mo, yung bagong pinalit mo e madaling masisira kasi cya yung nagaabsorb ng most of the vibrations kasi sira na rin yung iba, kaya sabi nya sakin e palitan ko sabay sabay yung mga defective na.
    Quote Originally Posted by Mamar View Post
    if you buy oem it would last for another ten years ;)
    Nov 2003
    somebody is pulling your leg. oem engine supports will be in the 3k range per pc. what you were quoted are replacement parts.
    OEM middle eng support ng altima ko 7K hehe, 4K sa gilid... So malabo ang 1200 kasi kahit sa 94 Corolla ko dati mga 3K na OEM
    Jan 2003
    1200??? japan replacement part lang yan. for sure duling ang isang butas nyan, kelangan mo pa kikilin para ma pasok yung bolt... at mas ramdam yung engine vibrations. pero sakit sa bulsa ng orig supports. yung sa hiace yung 2 big main supports 3k plus isa, yung 2 smaller sa ilalim 2k plus isa... this was 4 years ago...
    kaya tiniis ko na lang yung jap repalce kahit mas maalog
    Nov 2003
    actually, not all replacement supports need to have material ground off just to fit. most of them are getting better na and fit exactly now. we haven't had to grind off material in a couple of years pero i remember when we just started it was pretty common sa nakukuha namin na replacement supports.
Engine support question!
