Results 1 to 10 of 10
Threaded View
    Sep 2006
    Quote Originally Posted by StraightSix View Post
    Mawalang-galang na rin ... 'di naman kasi ako mekaniko at iba rin ang sasakyan. Pero halos pareho ang problema ko nuon - engine stalls getting more frequent and rough idles. Upon restarting, naka-"limp mode" yung engine - mahina hatak at walang kabuhay-buhay. Walang ring error display sa panel.
    I've checked the plugs, filter and used injector cleaners. I also tried to reset the ECU by disconnecting the battery. In the end, I had the ECU diagnosed for error codes and the culprit was the camshaft sensor.
    You must have a euro car? base on the limp mode.
engine stalls intermitently
