Results 1 to 13 of 13
    Hi,
    question, i have a honda City Exi 97 (1.3 engine) and I would like to upgrade my performance a bit. would my performance change a bit when I:
    1. Change my intake to a Standard Simota Air intake (aluminum tube, no available cold air intakes for 1.3 city)
    2. change my High Tension wire to a 9mm 5 core High Tension Wire
    3. get a Free flowing Muffler Tip (no budget for Muffler, hehe )
    and also, are there issues on aluminum intakes, that when it is too hot, hot air will go to the engine and on physics, hot air does not combust good?
    Need help on this guys, please? thanks
    Aug 2005
    Quote Originally Posted by mackkcam View Post
    Hi,
    How much are you willing to spend first?
    Which upgrade/s are your priority?
    My answer in bold letters
    Hi,
    1. Change my intake to a Standard Simota Air intake (aluminum tube, no available cold air intakes for 1.3 city) - [SIZE="4"]No[/SIZE]
    2. change my High Tension wire to a 9mm 5 core High Tension Wire - [SIZE="4"]No[/SIZE]
    3. get a Free flowing Muffler Tip (no budget for Muffler, hehe ) - [SIZE="4"]No[/SIZE]
    IMO you're better off saving up more, gutting out your old engine and putting in a surplus D15B engine.
    IMO, unless you turbo that thing, which is more expensive than getting a D15B, no matter what you put in there it will not give you sufficient power.
    Totally sayang pera.
    Simota filter - minimal effect. U wont notice anything.
    spark plug cables - minimal effect. U wont notice anything.
    muffler tip? u serious? for what? para masabi may "mod" ka sa exhaust?
    Nov 2003
    just get the simota. don't waste it on a tip and high tension wires. useless mods imo.
    any effect? ung intakes? may nbsa kc ako thread na useless daw un, pero para saan pa un kung di sya effective and another one is, what is the real purpose of upgrading the intakes...
    magkanu lng naman ang Tip, hehe
    Aug 2007
    just stay stock.. no effects din kahit naka simota air filter and high tension wire ka.. muffler pampapogi lang ng auto..
    I think that by now, you have a fairly good idea on what to do with your ride....
    4909:coffee:
    For 1.3L engines, just keep it stock. If you want more power, you have three options:
    -nitrous oxide
    -turbocharger upgrade
    -engine swap
    There are no "cheap" alternatives around it.
    How about port polishing?
    Marginal power increase for the amount of money spent. It might also result in much higher fuel consumption.
    Nov 2003
    the filter will help. normally all aftermarket filters give a little extra oomph.
    Jul 2006
    Quote Originally Posted by speedyfix View Post
    ...at the expense of more particulates getting through the air filter.
Engine question (for 1.3 engines)
