Results 11 to 17 of 17
May 9th, 2007 08:34 AM #11
good morning lets rolla!
your engine should be ok at around 600rpm on idle (via tachometer). the power system of the carb might be at fault then. this system is responsible for feeding the engine with ample air/fuel mixture at 2k rpm and above by opening a secondary barrel...the idle system of the carb can only handle up to about 1k rpm until it recruits the power system to attain a smoother running engine..(when you rev up to increase ground speed for example)
unless you have a leaking carburetor...gaskets, hoses...and other issues (like ignition timing!) your engine should be fine under normal operating conditions except for the tapping sounds you hear which i suspect is in the engine itself (valves, springs, etc)..
have it checked by an experienced mechanic so the problem is corrected at the soonest possible time to avoid further damage. it's kinda hard to pinpoint the problem without actually inspecting the engine.hope this helps a bit...
- May 2007
- 24
May 9th, 2007 09:05 AM #12
Hello sir, I suspect a leaking carb/vaccum line or a part of the carb that is faulty, as for the tappet well I just talked with the local machine shop the cheapest quote is 4.5k in labor and 1.8k in parts (overhaul kit including gaskets, etc) Thanks, I'll try to resolve the carb issue next weekend hopefully before elections, I hope fiday/saturday is payday though :D
May 9th, 2007 09:26 AM #13
- May 2007
- 24
May 9th, 2007 02:18 PM #14
May 11th, 2007 07:28 AM #15
soler and masangkay shops for cheap engine parts...abad santos for engine rebuilding...will get the name and contact nos. asap pag dumaan me abad santos...may i ask san ka ba malapit?kasi i would suggest you bring it to a shop near you where you'll be allowed to observe (if you've time to spare) it will be nice experience...
- May 2007
- 24
- May 2007
- 60
May 11th, 2007 09:52 AM #17
Automatic po Sir
