Results 1 to 6 of 6
January 26th, 2013 06:15 PM #1
what is the best engine oil/transmission oil additives have you tried???
January 27th, 2013 02:55 AM #3
The best thing you can do is put a inline transmission filter on a real magnet on the pan. The best magnet to use is a one out of a broken hard drive magnet they are about 10 times stronger than what's in most transmission magnets.
I use a magnafine inline filtter but they are not availible in the Philippines. But if you have someone overseas they can get one for you, They filter about 75% better than your in pan filter and remove 99.9 % of any metallic debris in your system. You can get them as cheap as 10usd and they last 30000 miles.
But just adding a few magnets to your pan keeps tons of wear damage from ever happening.
As far as additives go Lubergard is the only one that lives up to the hype, It's is manufactured OEM approved and the number one choice of transmission re-builders, Not sure if it can be found there either.
LUBEGARD Automatic Transmission Fluid Protectant
The guts of it.
January 27th, 2013 09:20 AM #4
Your standard motor oil and transmission fluid already have the necessary additivies mixed in. There's really no need to add anything else unless you know exactly what you're doing.
January 27th, 2013 05:14 PM #5
- Sep 2004
- 58
February 1st, 2013 05:12 PM #6How much and saan makakabili ng LUBEGARD Automatic Transmission Fluid Protectant?
