Results 11 to 19 of 19
February 15th, 2008 09:03 PM #11
Thanks XTO siguro orig na lang bilin ko para sure na tatagal. Mga magkano nga pala orig na crankshaft oil seal ngayon for hilander? Salamat ulit!
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 17th, 2008 09:23 PM #12oil seals will leak no matter if you replace the oil often. it comes with age talaga.
February 25th, 2008 12:36 PM #13
nakapag palit na din ako sa wakas ng crank shaft oil seal so far sulit naman pagkakabili ko sa OEM na oil seal, zero leak na ulit ang ride ko sinabay ko na din yung clutch ko malapit na din sya maupod and pati bearing nya. change oil din tranny thanks sa mga advise.
- Jul 2007
- 46
March 8th, 2008 03:39 AM #14
sir speedyfix, tanong ko lang, May napapansin ako na oil leak very slight..malapit dun sa engine code eh i have a civic SIR, pero hindi naman tumatagas pababa, parang nag momoist lang sa mga small wiring and tubes na nakaconnect sa engine which is i think vtec solenoid, at dun sa corner ng engine where you could see the metal sheet separating the top side of the engine and the low side don't know what it is exactly called. makikita mo cya pagbukas mo sa hood, i also have checked other SIRs ganito rin nakikita ko..magmomoist here's a picture, ano kaya toh?
March 8th, 2008 10:18 AM #15
sir sabi kasi sa akin ng mechanic na pag binawasan yun spring ng oil seal mas lalo daw tatagal. totoo po ba yun?
March 8th, 2008 01:33 PM #16
hey bro, you might want to check the Distributor O-ring and the rear Camshaft Seal (Exhaust Cam). since sometimes diyan din nanggagaling ang leak. also, I believe that theres an Oil Pressure sensor sa gilid ng head (doon sa may picture na pinost mo na may sinabing "slight leak".).
anywayz, those are the places na pwedeng panggalingan ng Oil leak (sa side ng engine na yun ha.. as per what you post on that picture. specially on D, B , and H series Honda engines w/ V-TEC.)
aite, peace.Last edited by KBR; March 8th, 2008 at 01:38 PM.
March 8th, 2008 01:36 PM #17
- Nov 2003
- 3,849
March 9th, 2008 03:37 PM #18the engine in the picture is a h22 so not the same as the sir engine. but normally the only things that will leak on the left portion are the distributor o-ring and oil seal, vtec solenoid gasket and strainer, cam seal and/or the valvecover gasket.
March 10th, 2009 12:12 AM #19
adventure 98 4d56.
pwede po pwede ba paki lista niyo mga oil seal ng makina namin?? nasa 3 months na may tulo garahe namin. every overnight parking ay nasa 1 spoon ng oil ang tumutulo..
para lang po magkaroon ako ng idea kung magkano ihahandang pang gastos.. paki indicate na rin ng estimated price sa parts and labor sa pagpapalit..
Suzuki JIMNY [merged threads]
