Results 31 to 40 of 56
August 3rd, 2020 04:04 PM #31
Ang diesel hindi tinataasan ng ECU ang RPM pag cold start. Kahit taasan ang RPM pag tinapakan mo yung pedal at neutral hindi rin masyado tataas temperature kasi walang load.
Idle lang for maybe 15-20 seconds tapos drive away slowly for the first km or so. Pag mainit na makina after a few minutes pwede na bilisan takbo/taasan RPM.
August 3rd, 2020 04:09 PM #32
Pag start ninyo ng engine then magsuot ng seatbelt turn on A/C pwede na kayo umalis huwag na painit ng makina.
Hinde kayo mga lumang tao para gawin yan. Baka pati yun pa tapat ng gas bago off engine ginagawa din?
August 3rd, 2020 04:24 PM #34
August 3rd, 2020 04:32 PM #35
August 3rd, 2020 04:32 PM #36
Kung short drive lang, puwede naman. However, a half minute of idle before turning it off wouldn’t be a big hassle.
Pero kung galing long drive, give it 2 minutes to let the engine idle before turning off.
Better be safe than sorry. It will be a head ache if you break your turbocharger.
Di ako puwede humataw sa loob ng subdivision, bro. Hehehe
- Oct 2014
- 37
August 3rd, 2020 04:33 PM #37Yun nga. Malaking issue sakin un kasi di nila inuupdate customer nila. Walang transparency. Be aware na lang siguro. THis is ValuePlus E. Rod. btw. I should have done my research, I've actually been reading reviews na ibang parts na gamit nila questionable quality. They are not that cheaper than the casa too.
- Oct 2014
- 37
August 3rd, 2020 04:35 PM #38I actually asked them if I could bring my own oil to which they vehemently refused kasi daw "policy". This is from ValuePlus E. Rod. Kaya nagka leche leche. I guess I should have been more vigilant and they should ahve been more transparent.
- Oct 2014
- 37
August 3rd, 2020 04:37 PM #39
- Oct 2014
- 37
August 3rd, 2020 04:40 PM #40
Kaya maganda supportahan ang local Yokohamas. Fresh from the factory. Hindi dumaan sa biyaheng...
[AutoIndustriya] Tires older than 5 years old not...
