Results 1 to 15 of 15
    Jan 2008
    I have a lancer itlog 93 and I need help the problem is when I rev my car it emits white smoke. How can i resolve this issue and what causes it? already change my oil last october.
    How is your idling?
    Jan 2008
    [pag idle chief its normal. once lang na nag rev ako saka siya na eemit ng smoke
    Nov 2003
    if there is smoke then normally it is something wrong inside the engine like piston rings or valve seals.
    Jan 2008
    Mga master sana you could help me on my problem. Coz i really need your expertise to have my car as smooth as possible and problem free
    hinde ba nauubos ang water mo?
    Jan 2008
    I bought it 2nd hand last august 2007 and ever since i bought it di na ako naglalagay ng tubig. di siya nag ooverheat and never siya nababawasan ng tubig
    Jan 2008
    Quote Originally Posted by speedyfix View Post
    pero chief eto lang ba talaga ang normally causes of smoke
    how much usually charge sa pag palit ng mga piston ring or valve seals?
    and any recommended shops ?
    Jan 2008
    up lng po sa post ko just need help on this
    Jan 2008
    Quote Originally Posted by zach09 View Post
    sir pwede ba mag pa estimate ako sayo for this problem. Hope you could fix it
    Jan 2008
    Yung lumang-luma kong kotse nagkaganyan din pero swerte naman at makapal na carbon lang pala sa exhaust sytem na na-saturate ng tubig naidaan kasi sa baha. Linis, palit tambutso at takbo lang yung kotse ng medyo malayo. Di na rin umulit.
    Wala ba oil leaks engine mo excessive blow-by or oils sa paligid ng valve cover.
    Pero di ka naman maghihikahos sa Top Overhaul, PM mo na lang si sir speedyfix bago lumala problema car mo.
    Jan 2008
    Tnx mga boss
    is it possible na baka pwede change oil lang siya kasis last ko pong change oil is last year october pa
    Jan 2008
    This only happened once when we went up to antipolo with 5 passengers with me . the next day when i've tested it walang usok ive tried it the second time wala parin usok nag rev ako ng nag rev wala parin usok . Pretty strange di ko na talaga tuloy alam kung bakit ganun siya
    still need help just to make sure that it wont happen again or to prevent it from happening
    Aug 2006
    nagkaka white smoke pag cold start? or pag matagal na ginagamit?
    1. try to check if nagbabawas yung oil mo
    2. try mo pa compression test kay sir speedyfix, mura lang yun, para malaman kung ano possible problem..
    HTH...
    Nov 2003
    it might have to be checked so you can say for sure what the problem is. mas mabuti kung makita ng mechanic what is wrong and tell him the symptoms/problems so that they can check specifically for that
Need help Excessive white smoke
