Results 1 to 15 of 15
    I'm using my car everyday travelling from Novaliches to my office at Ortigas. I put about 1 liter of engine oil every 3 weeks because everytime i check (every 3 wks), oil level as checked through my dip stick is almost 0. Is this normal? Please help. 96 mitsu glxi . thanks
    Feb 2006
    Quote Originally Posted by kudil View Post
    pa check mo na car mo sa mekaniko baka may tagas yan or kailangan na ng OH
    no it's not normal...have it check ASAP!!! teka lang bakit 1 liter lang nilalagay mo kung almost zero na ang oil level mo, hinde mo tinitingnan yun ilalim ng kotse sa sahig mo during morning baka tumatagas din
    May 2004
    bro, check mo kung me tagas nga. Lakas naman nyan umubos ng oil.
    Aug 2003
    check your garage floor for oil spots
    Check all your oil seals.
    Maybe the gasket in your oil pan is compromised.
    When you leave a parking spot, do you see droplets of oil that weren't there when you parked.
    That is a sign that it's leaking out somewhere.
    Try putting newspaper underneath your vehicle at night. If you see oil stains, that will confirm you have a leak also, it will help you isolate which side or part of the engine the leak is coming from.
    Hope this helps.
    Ipa-check mo na ang kotse mo. Nangyari sa akin din yan noon na 92 Corolla pa ang gamit ko. Nagsawa ako sa pagpapaayos pati na rin sa gastos kaya binenta ko na lang.
    they're right. have your oil seals, oil filter and oil pan nut checked for leaks. had change oil last july and had the nut changed as well. noticed that the engine was losing oil but in a slow pace. turned out that the nut was already worn.
    Nov 2003
    is the car smokey? if there are no leaks the engine might be the one consuming the oil through a bad set of piston rings or valve seals.
    Nov 2007
    Quote Originally Posted by speedyfix View Post
    * sir speedy, how do i determine if i already have a defective or worn out valve seals? Parehas kasi kami ng prob ni threadstarter, nauubos ung langis ng wla naman leak sa engine, and wala rin smoke...
    Magkano kaya if ever ang repair ng piston rings/valve seals... thanks
    Nov 2003
    bad rings or valve seals will show by causing a lot of smoke when you rev the engine.
    price to replace the parts depends on the engine and what else needs to be done.
    Jan 2008
    Quote Originally Posted by Onynz View Post
    Palagay ko di mekaniko kelangan dito kundi detektib baka may nagnanakaw ng langis Fully Synthetic siguro gamit .
    Aug 2005
    Delikado sa makina ang maubusan ng langis. Better have it checked.
    Aug 2006
    ganun din nangyari sa akin datin...pero mas malala sa akin...every week ako nag checheck ng dipstick ko...parati sa kalahati yung oil level ko...wala namang tagas or smoke...
    nag canvass ako kung magkano pa OH, 30k+, hinde nadaw kaya sa top OH, kaya i decided to change my engine...30k + 20k, wala na problem oto ko...bulsa ko nalang...
    pero worth it talaga...
    pero pag nagtitipid ka...pag hinde pa na Top OH yan...try mo pa Top OH baka kaya sa ganun lang...or baka naman valve seal lang yung culprit...
    the best steps is pa check mo kay sir speedyfix...2 hands up ako sa service nila...mura na..pulido pa...hehehe
    Nov 2003
    hehe! thanks bro!
Engine oil
