Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Jan 2004
    3E puwede na yan. Halos kapresyo lang ng 2E na surplus.
    Jun 2006
    magkano ba yung engine?
    Feb 2005
    medyo mahal nga ang 4AGE.. dapat magpapalit na din ako ng engine kasi blow-by na makina ko e.. sayang naman kung overhaul lang tapos konting dagdag na lang pala e mas magandang engine pa.. last i heard 4AGE blacktop is around 30K and the 4AGE silvertop is 50K.. or is it vice versa? nakalimutan ko na kung ano ang mas malakas.. silver ba or black? baliktad yata pero anyway rough estimate lang naman yun..
    Quote Originally Posted by Marc MD
    pinaka-mahal black top. red-silver-black.
    4AFE ka na lang sir. subok na.
    Quote Originally Posted by mames20
    pwede po bang upgarde ung 4AF na engie sa 4AFE
    upgrading the 4AF to a 4AFE? ... if you are thinking of simply changing some parts, no. It would be simpler to do an engine swap to upgrade from a 4AF to a 4AFE since the 4AFE engine does have some sensors and other electronics required to make the engine run smoothly and reliably.
    On the other hand, there used to be an "upgrade" kit to convert a carb engine to a basic fuel injected engine but I doubt if its available locally.
    its the other way around.
    the 4AGE 20valve silvertop is cheaper then the blacktop. And your estimated price doesn't include labor nor parts you will be replacing before installing a surplus engine like belts, filters, hoses, etc.
    A 4AGE-20v silvertop (roughly 145hp) would cost around P50K installed with labor.
    A 4AGE-20v blacktop (roughly 160hp) would cost around P70K installed with labor.
    A cheaper option is the 4AGE 16valve engine. Its roughly 135hp.
engine inquiry
