Results 11 to 20 of 22
November 24th, 2002 03:41 PM #12Originally Posted by afrasay
- 197
November 25th, 2002 11:29 AM #13Saksakan mo nalang ng compressor sa oil filler pagkatapos ma-drain ng langis. This will empty your engine enough and yung matitira na oil is sufficient enough to seal the important parts.
Learned this from race mechanics who have to change the oil in a flash. ;)
November 26th, 2002 12:21 PM #14
RS Sprint
make sure lang na hindi madumi yung hangin nung compressor mo. may mga shops kasi na nago-oil change na madumi hangin kaya pumapasok sa loob yung dumi kaya bale wala oil change mo :?
- 37
December 1st, 2002 04:34 PM #16
May nabasa naman ako sa isang site gamit daw ng ATF mga 1 liter added to the old oil kasi may detergent action daw ang atf. run it for a few minutes then drain the oil. change filter and add new oil. \
December 1st, 2002 11:09 PM #17
i was thinking of engine flush then drain, then add 3 liters of regular oil, run again 5 mins then drain, then put fully synthetic oil 6 liters then yun na. wat u guys think??????
December 2nd, 2002 12:01 PM #18
KCboy, ang dami mo atang pera a :lol: Pero ganyan din dapat gagawin ko sa kotse ko e, dahil nga ayoko gumamit ng engine flush.
December 5th, 2002 08:48 AM #19
ako engine flush then after, 3liters of oil para maalis yung chemicals ng engine flush, i just used 3liters of cheap 75php oil. ayun luminis yung 4d56icturbo ko. ganda talaga fully synthetic oil, i use mobil 1. maximize talaga performance ng pajero ko.
- Nov 2002
- 65
December 6th, 2002 09:15 PM #20if you want to engine flush ok lang basta make it sure na tuyong-tuyo ang oil pan mo...yung wala talagang natitira...ofcourse mas ok pa rin na di mo engine flush like everybody sez...
Automatic po Sir
