Results 11 to 20 of 20
December 9th, 2013 03:11 PM #11
No, drain the old oil first, BUT do not remove the old filter yet.
- Jul 2013
- 48
December 9th, 2013 10:03 PM #12drain ko lahat tapos 5 liters of diesel ilalagay ko paandarin ng 2min... walang magiging problem sir?????
December 9th, 2013 10:25 PM #13
This works for gas engine and diesel engine? Thanks!
Sent from my LG-D802 using Tsikot Forums Mobile App mobile appBeep Beep! School Bus! Beep Beep! School Bus!
- Mar 2013
- 139
December 11th, 2013 12:17 AM #15ganyan din ginawa ko kay lowslowbenz pero yung sludge talaga sa valves parang aspalto na ewan ko lang sa oil pan kung ano itsura wala pa akong torque wrench set para buksan 13t engine
December 30th, 2013 10:38 AM #16
This is just the way to free the sludge and gunk in there. But for me, I'll use a high detergent diesel engine oil constantly for short OCIs, say 3,000 kms, 3 to 4 times, until I'm satisfied that my engine is gunk free. Alam naman natin na sludge does not develop in so short a time, so it also takes time to dissolve it.
I change oil DIY only. Drain the oil in a clean pan while it is still warm so it flows easily. Leave it dripping for an hour or two, I come back just when the oil filter is already cold to be removed by hand, install a new filter, tightening it by hand only, the drain plug by a wrench siempre. Wipe all the mess, put the old oil in a jug with tight cap for proper disposal, pour the new oil, start the engine, let it run for 10 minutes, turn off, check for leaks and also the oil level. That's it! Wala na kung ano-ano pa flushing, waste of money. Besides, you can not clean thoroughly what you can not see!
Posted via Tsikot Mobile App
- Mar 2009
- 184
January 5th, 2014 10:11 PM #17Subukan ninyo mag lagay ng goma sa diesel at tingnan ninyo kung di matunaw yung goma. Yan ang delikado. Kapag gumamit ka ng diesel, lalambot na yung mga rubber oil seals sa makina, crankshaft oil seal, camshaft oil seal, etc. At siyempre kapag lumambot na yan, malamang mag-lileak na rin. Mas malaking trabaho, kasi ibababa mo yung head o yung makina mo para lang palitan yang mga oil seal. Syempre aasa ka na rin na sana hindi nakapasok yung mga dumi dyan na may mga abrasives na nakaka damage sa mga bearings, shafts, etc. Kaya mas mainam kung palitan mo yung oil regularly. Kahit anong kotse pa yan, gas o diesel, ang sikreto sa pag tagal ng makina ay nasa pag palit ng langis regularly. Kung 5k o 10k, depende sa gamit, sa load, sa trapiko, kondisyon ng paligiran, etc. Pero flush with regular oil.
Kung may sludge na lang siguro ko susubukan yung diesel pero baka too late na rin kasi kapag may sludge, usually, marami na ring bara. Di matatanggal lahat ng sludge kahit i-flush ng diesel. Kailangan buksan pa rin ang makina para siguradong walang mga bara katulad ng strainer, mga cylinder jacket.
- Apr 2009
- 429
January 10th, 2014 12:29 AM #18
- 52,700
January 10th, 2014 09:28 AM #20
