Results 1 to 18 of 18
    im currently using Caltex Delo500 SAE40 for my lc80. is this good enough or does the turbo need a multigrade? any suggestions?
    Dec 2002
    Multigrade is better, eg, Delo 500 15w40. I've used Delvac MX 15w40 with good results. Now using Delvac 1 5w40, full synth- engine runs smoother on it and drain interval up to 6k km.
    How often do you change oil? Do you have any smoke from exhaust?
    I think with the the added stress to the oil brought about by the turbo heat, multigrade would be more adviseable.
    Mobil already has a new Delvac line with the latest API rating.
    Delo GOLD is multigrade na ba? hehehehe. Ilalagay ko kasi dun sa imaginary LC80 namin ni mbt, eh.
    how about the new delo sport?
    Sa pagkakabasa ko sa Delo Sport, ito ay mineral based oil with synthetic blends.
    every 5T km, no smoke naman
    Jan 2004
    My humble opinion pag sa tropics di naman kailangan talaga multi viscosity kasi constant ang temps natin. Sa mga lumalamig lang yan na bansa. Marketing hype I guess. Ako, straight 40 ayos na par siguradong d manipis ang langis.
    Feb 2004
    Im not sure about this, pero palagay ko ayaw tumulo ang single grade 40 na motor oil at 75 deg F. Normal temp range dito sa atin is around 75 - 88 deg F. Im thinking na baka pag pina andar ang makina na 75 deg F matatagalan pa bago mag circulate ang oil dahil masyadong madikit pa ito. Whereas kung multigrade oil, dadaloy kaagad kaya ma minimize yung time period na walang lubricant yung mga piyesa ng makina. This would especially affect cars that are in colder locales like Baguio.
    Jan 2004
    Actually, an SAE30 straight weight was tested by SAE flow properly as low as 32 deg F(O centigrade). In fact if you look at a Pajero Manual the approved temperature range for 30 weight single grade starts at 32 degrees and up.
    By the way , the "W" you read in multigrades e.g. 15W40 stands for WINTER not Weight. We really don't have winters in RP.
    So, 40 single grade is really great for diesels and turbodiesels. I am very wary about multigrades becasue of the VI's(viscosity improvers that just improve flow at very low temps but do not really help in lubricating, sometimes causes damage to engines at high temps).
    Straight 40 is great for 55 degrees F and above. Unless you live in Mt Pulag, I wouldnt worry about 40 weight in RP
    Feb 2004
    Point taken.
    Dec 2002
    VI- can also mean viscosity index, which measures the length of time for the oil to break down. Most single grade oils are below 100 while multi-grades are at 130+. Synthetic oils start at about 160+.
    The other component of newer oils is the additive package wherein a higher API rating usually means better additives. These additives protect the base oil from soot, acids which, inevitably shorten the life of a diesel oil.
    The mobil site (www.mobil.com.au) has a lubrication guide for most cars/suvs, almost all use a multi-grade oil- australia has extremes in temp, like 40deg summers.
    Jan 2004
    Viscosity index is really the ability of an oil to maintain its thickness or thinness(viscosity) over a WIDE temperature range.
    It has nothing to do with lubricating abilities. The index is more usefull for temperature climates where huge temp swings are normal year round, say 20 deg F to 90 F year round. The higher the index the better for these locations.
    At 212 F(100 Centigrade) engine temps 5W30 10W30 Straight 30
    oils have the same viscosity, they are the same oil. PAg malamig lang nagkakatalo! Ngayon, pag 30 degress F na ang weather dyan matatalo ang straight weight oil. Like I said in earlier post
    when do we get 30 degree weather in RP?
    Kaya ko lang gusto ang straight weight sa hotter running engines like turbodiesels is that at higher viscosities (straight 40 or 50 it withstands heat a lot better and wala syang halo na viscosity improvers which tend to break down in high heat.
    BTW Australia is known to be a hot place, your right, but they use multigrades there because it also gets real COLD in a lot of places BRRRRRR
    Dec 2002
    ezgrand
    So what oil do you actually use? In what application, engine? What's the Api/Acea rating of the oil?
    Have you ever done a used oil analysis locally to determine viscosity at both 40 and 100deg, TBN, VIndex, insolubles? I have on a multi grade 5w30 synth oil.
    Jan 2004
    Jack, I use Mobil or Caltex straight weight 40 on my Toyota 2LTE. I've also used it on Mistubishi and Toyota engines for 10 years without any problems. As I mentioned viscosity improvers are just that viscosity improvers that do nothing to help lubricate an oil better in a tropical country where the temps don't really fluctuate.
    BTW I think you are kinda confused regards viscosity which is really comes into play in AMBIENT temps! how can I test my oil viscosity at 40 deg F when our temps in Manila never go that low!
    Dec 2002
    ez,
    The tests done measure viscosity at 40 and 100 deg C so they show what happens within an engine. Think that the performance of an oil at normal working temps of an engine matter more than ambient temps. A turbo adds stress on the oil, just as high sulfur fuel, egr's, soot. Used oil specs would give you an idea if the oil can handle all these factors.
    If the oil were to breakdown then you form a sludge which can ruin an engine. This sludge can be prevented by the use of the right additives, which i think you call viscosity improvers, or better base oils.
    I do not doubt that the sae40 works but i too have used multi grades for more than 10 yrs and have never had problems.
    Jan 2004
    Jack, thanks for the info! Noted! My original posts were just meant to explain that the lower numbers in a multi grade oil is meant for real cold weather and that "W" stands for winter.
    just wanted to stress that straight oil is good enough for the tropics! my humbel opinion.
    Dec 2002
    ez,
    This is from an article on synthetic oils, and what lower viscosities do for an engine. Hope this helps.
    Quote:
    It is also important to note that, contrary to what many take for
    granted, higher viscosity in and of itself does not translate into better
    engine protection. Extensive testing has shown the opposite to be in
    fact true. As long as a lower-viscosity oil is formulated to resist
    evaporation and provide high film strength, this lighter oil will
    actually deliver more complete protection to the engine parts, since its
    more rapid circulation delivers both better lubrication per se, and far
    better cooling characteristics...a critical advantage, given that oil
    flow furnishes up to 30% of an engine cooling requirements. Prior to
    the introduction of synthetics, however, the problem of evaporation (and
    the resultant thickening of the remaining oil) was addressed primarily
    by increasing viscosity. In short, don't be concerned with the
    relatively lower viscosity ratings of some synthetics. Syn lubes are a
    whole new ball game.
    Quote:
    Viscosity is a crucial consideration when improvements in fuel economy
    are desired. It stands to reason that the freer and engine turns, the
    less fuel it will require to accomplish a given amount of work. Studies
    have demonstrated conclusively that engine drag is directly related to
    the viscosity of the motor oil. Generally speaking, the lower the
    viscosity, the better the fuel economy of the engine. In formulating
    lower-viscosity oils, it has become clear that synthetics are the base
    stock of choice. This is because it is possible to produce a synthetic
    oil of a given low viscosity without incurring the excessive oil
    consumption (due to evaporation) and resultant thickening of the same
    low-viscosity petroleum oil.
    Quote:
    High temperature
    stability, as well as oxidation-resistance, is of absolutely paramount
    importance when it comes to turbocharged engines. Because it must both
    lubricate *and cool* the turbo unit, the oil MUST be specifically
    formulated to withstand the turbo's extremely high operating
    temperatures. Oil film temperatures often exceed 450F in the turbo unit
    during operation, and can surpass 650F(!!!) during a short period
    immediately following engine shutdown...both figures far exceeding the
    thermal limits of petroleum oil. Synthetics, with their capacity to
    maintain proper (low) viscosity and lubricity under these high heat and
    stress conditions, and with their natural resistance to oxidation, have
    risen to the fore. It is also important to note that the
    high-temperature-stability properties of synthetics are *designed
    primarily into the base-stock oil itself*, rather than being achieved
    primarily with additives.
Engine oil for LC80
