Results 11 to 13 of 13
July 21st, 2013 09:58 PM #11
Sir, better have a qualified mechanic check it para makasigurado tayo.
- Feb 2013
- 14
July 22nd, 2013 02:37 PM #12Had it checked out this morning. Pinalitan spark plugs, nangingitim. Then eventually, kinalas yung karburador at nilinis, then binalik. Kaso di nila maayos. Medyo ok yung andar pag di nakakabit yung pipe assembly ng air filter. Pag kinabit, namamatay. Namamatay din pag binuksan ang aircon. So far pinabyahe na lang muna nila ko na nakakabit yung pipe assembly sa karburador, pero di naka-feed dun sa engine. Bawal din muna mag-AC. Sabi nila paayos ko daw muna sa specialist ng karburador.
I need recommendations for carb specialists, preferrably in the south. Taga-Paranaque po kase ako at medyo nag-aalangan ako bumyahe nang malayo at baka itirik ako nung van. TIA.
July 22nd, 2013 02:51 PM #13
Mga vaccum hose ba yung sinabi nya?
Possible din kasi na magbara yan eh all you need to do is remove is and have it clean by blowing pressurized air or replace it entirely kasi nasa around 30 pesos per feet lang naman yan to replace
Hybrids and EV
