Results 1 to 7 of 7
- Apr 2006
- 11
April 10th, 2006 12:48 AM #11. hi to all, bago lang po ako nag oto, 2 weeks pa lang, 98 city manual nabili ko and reading from auto forums is helping me a lot, just a experienced after turning on the engine(para painitin makina at buksan aircon para palamigin kasi meron kami lakad) that after a while nag indicate yung batt at nag pahiwatig na mamatay engine...namatay na nga, di ko na ma istart kaya pi nakadyot ko and then nagstart naman,,, kala ko kasi kapag takbo na makina okay na i on a/c kahit stationary pa...ano kaya possible nangyari??? ngayon okay naman oto, kaya lang me kaba baka mangyari uli...
2. isa lang po ba uri ng coolant sa lahat ng oto? i've observe kasi konte na lang yung nasa container(pag bukas ng hood)...thanks in advance sa lahat ng sasagot...
April 10th, 2006 01:24 AM #2kala ko kasi kapag takbo na makina okay na i on a/c kahit stationary pa
April 10th, 2006 01:46 AM #3Originally Posted by bennysy
2,normally may indicator sa container kung hanggang saan ang coolant,and I'm not sure pare-pareho lang ang lahat ng coolant,,wait mo nalang ibang posts ng iba pa nating fellow tsikoteers na expert sa mga ganyang problema..
April 10th, 2006 10:48 AM #4
My 50 cents..A good place to start would be the ignition system. Most misses are caused be a defective, worn or cracked spark plug. Ignition wires break down over time and can allow the voltage that should be going to the spark plugs actually ground out against the engine. If the plugs and wires are ok then the next step would be to check fuel pressure and the volume of fuel.
April 10th, 2006 11:51 AM #5
ps check mo compressor ng aircon mo. baka stuck up na yun bearing kaya when you turn it on biglang nagkakaload na malaki ang engine.
- Apr 2006
- 11
April 25th, 2006 02:44 AM #6thanks guys, i've really considered all your inputs, ironically, when the car mx check
the alternator, batt, and compressor - they are all in good cond. but found one problem in my clutch-kaya pala mahina na hatak, kailangan palitan ng clutch disc, so far ok na condition ng oto, enjoy ako with family...again thanks sa help nyo...benny
April 25th, 2006 08:16 AM #7
you might want to check your idling also sir if its dropping when you turn on the a/c, stereo, headlights, etc.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
