Results 1 to 10 of 10
May 9th, 2013 07:54 AM #1
Galant MPI 89 namamatay makina pag bitaw sa acceleration pedal, lalo na pag mlapit sa sa humps or stop light basta bumagal ang takbo namamatay sya ano po problem nito?
- Jun 2005
- 3,762
May 9th, 2013 08:10 AM #2Hulaan ko? Naka aircon ka no?
Try no palinis servo. Kung di kaya, baka palitin na
May 9th, 2013 12:56 PM #3
May 15th, 2013 11:10 AM #4
update ko lang ito nawawalan ng kuryente, labas check engine, nya posible kaya sa alternator or sa distributor problem nito? umaandar naman sya kaylangan lang bombahin lagi silinyador para di mamatay kaso nalabas ang check engine, 1 click start naman sya
May 15th, 2013 03:54 PM #5
die engine, die!
if the stalling of the engine happens when you let off the gas pedal, your idle speed maybe too low. with a galant, i would assume you have a four banger of an engine. the idle speed should be around 750 without engine load (climate control off, steering at straight ahead, transmission in neutral and engine is fully warmed up. cleaning the throttle body and the idle air control has always been a part of engine tuneup among other things.
May 15th, 2013 04:14 PM #6
sinagad ko na adjustment ng SAS, check engine light umiilaw sa dash board i hold the acceleration to the mid position(sabay laro laro) para hinde mamatay ang engine, but the engine take slowly to die, i press the acceleration pedal again para hinde sya mamatay, when i release the pedal it going to die, i think na may problem sya sa ignition coil, how to determine kung may damage ang aking ignition coil? tingnanggal ko yung main high tension wire (yung nasa gitna)sunog yung dulo at walang contact sa kabila ng gamitan ko ng multi tester, pinalitan ko but same problem pa rin,namamatay pa rin,parang nawawala yung kuryente
May 15th, 2013 04:20 PM #7
can you identify your engine type and engine family? normally, you don't macgyver your mechanical throttle adjusting screws. how is your engine vacuum? if the engine has less than 17 inches of mercury vacuum at idle, chances are your valve timing is off from a worn out or stretched timing belt or the timing belt skipped.
May 15th, 2013 04:41 PM #8
May 16th, 2013 09:30 AM #9
May 24th, 2013 09:50 AM #10
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
