Results 1 to 10 of 21
November 23rd, 2004 12:34 PM #1
paano ito ginagawa? mahal ba ito? any recommended shop near greenhills or pasig?
kasi napapansin ko these past few days na medyo hirap na sa mga paahon o akyatan itong 12 year old lancer EL ko lalu na kung naka-aircon. dati naman hindi siya kinakapos sa mga akyatan kasi. may nakapagsabi sa akin kasi na ipa-compression test ko ang engine ko. tama ba yung advice na ito sa akin? thanks and more power!
November 23rd, 2004 01:49 PM #2
we had this done to our mazda323 before we entered it into a car-loan program. this was done since the car was already a few years old.
we had it done at ziebart's
November 23rd, 2004 02:20 PM #3
I had our compression test done in Kartek Santolan-Ortigas before (mga P300+ ata yung charge nila).
Try going to Speedyfix along Santolan in San Juan (across Kartek).
November 23rd, 2004 03:04 PM #5Originally posted by niwde11
mga sir, gano sya katagal?
November 23rd, 2004 04:11 PM #6Originally posted by mazdamazda
30 minutes lang yata
November 23rd, 2004 10:51 PM #7
Ano po ba gain nito?
Please explain lang po further sa mga wlang alam na tulad ko. hehehehe
Interesado po ako... kung maganda po sa car ko.
November 24th, 2004 03:39 AM #8
Compression testing is for when you think you're losing power due to a blown gasket or oil seals...
It's also a good idea to do this for old engines after a certain period of time... It will tell you if you need an overhaul.
November 24th, 2004 09:41 AM #9
In gas engines, they just insert the testing probe thingee into one cylinder at a time via the spark plug holes then you crank the engine several times to get the compression readings. They do both a wet and dry test... if your car fails at the wet test, i think its a busted piston ring.
It also helps when you're buying a second hand car so you'll see if the engine is a-ok.
November 28th, 2004 05:30 PM #10
ok. let me have my say about compression. if you can't go to a shop then, try this one. when going into downhill, (assuming that you have a M/T), shift in to first gear and let go of clutch, brakes and accelerator pedals respectively. if the car maintains its speed without giving in to the pull of gravity(downhill right?) then compression is still good because of the piston rings were tight enough. on the other hand if the opposite occurs (you picked up speed), then chances are piston rings are loose enough and will have to replace it soon.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
