Results 1 to 8 of 8
March 25th, 2011 03:32 PM #1
Mga Bossing,
Tanong lang po. Naka 1st gear naman pero pag paakyat parang mamatay ung makina pag mga ilang oras na kau sa biyahe. pero pag mga couple of hours palang walang problema. basta pag mahaba na ung biyahe parang hirap na umakyan. Manual Transmission Ano po kayang problema ok naman ung temp gauge. sana may makatulong
- Apr 2010
- 268
March 26th, 2011 11:46 AM #2anung make and model ng car po? anung engine?
Same experience with our fx 5k before. Nabubulunan pag paaakyat.
What I did:
1. carb overhaul (eto ang culprit in my case)
2. change fuel lines
3. change fuel filter
4. check fuel pump (okay pa naman)
5. change spark plugs
6. change oil.
7. change oil filter.
8. check clutch parts
9. clean distributor cap
10. changed hi-tension wires (seiwa brand)
3k lang nagastos ko. ayun ok na takbo. and also check engine oil level bro. kung may mga leaks ang engine malaman malaking factor yun. watchout for signs of blowby din bro. search mo dito sa forums. sana nakatulong.
thanks
- Jan 2005
- 445
March 28th, 2011 04:17 PM #3Anong car? Anong engine? Carburated or EFI? Turbo or naturally aspirated?
March 29th, 2011 09:40 AM #5
Bossing Shepherd,
Ung sayo eh gasoline din ba? pagmatagal nang tumatakbo lang un hirap umakyat hindi rin hirap magstart pero may parang singaw na shhhhh na naririnig pag ini-start parang tunog na galing sa starter.
March 29th, 2011 10:21 AM #6
Toyota 7K engine carburator type engine . Gaano na ba katagal sa iyo sasakyan at kelan mo pa napalinis carburator mo . Tama ba timpla ng air fuel mixture ng carburator . Maraming pang gagalingan problema ng sasakyan mo Kailangan maganda rin supply ng kuryente ng disributor mo at tama ang timing ng engine . Check mo rin iyong clutch disc baka worn out na .
- Jan 2011
- 123
March 29th, 2011 02:51 PM #7
