Quote Originally Posted by Warlock987 View Post
Mga Bossing,
Tanong lang po. Naka 1st gear naman pero pag paakyat parang mamatay ung makina pag mga ilang oras na kau sa biyahe. pero pag mga couple of hours palang walang problema. basta pag mahaba na ung biyahe parang hirap na umakyan. Manual Transmission Ano po kayang problema ok naman ung temp gauge. sana may makatulong
anung make and model ng car po? anung engine?
Same experience with our fx 5k before. Nabubulunan pag paaakyat.
What I did:
1. carb overhaul (eto ang culprit in my case)
2. change fuel lines
3. change fuel filter
4. check fuel pump (okay pa naman)
5. change spark plugs
6. change oil.
7. change oil filter.
8. check clutch parts
9. clean distributor cap
10. changed hi-tension wires (seiwa brand)
3k lang nagastos ko. ayun ok na takbo. and also check engine oil level bro. kung may mga leaks ang engine malaman malaking factor yun. watchout for signs of blowby din bro. search mo dito sa forums. sana nakatulong.
thanks
