Results 21 to 30 of 30
February 14th, 2009 05:48 PM #21
February 15th, 2009 06:59 AM #22
Ano signs na dapat nang palitan ang timing belt? kakatune-up lang kasi ng 98 lancer el ko. sabi ng mekaniko samen ok pa daw ang timing belt. tsaka magkano naman aabutin ng palit ng timing belt? thanks mga tsikoteers!
- Feb 2008
- 577
February 15th, 2009 10:50 AM #24
It should be mentioned in the owner's manual. It will indicate that the timing belt be replaced after x number of kilometers or y number of years, whichever comes first.
Replace the timing belt ON or BEFORE any of the conditions stated in the manual (no. of km traveled or number of years used) is reached. Don't wait for any signs of wear to appear before you replace them. Belts are inexpensive... A new engine isn't.
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 16th, 2009 09:53 AM #26
Did some reading last night.
This is from Automotive Mechanics 10th edition by Crouse-Anglin. Page 334
" Sometimes a good belt will slip and squeal even if properly tensioned. A belt dressing can be applied to friction sides of the belt. This may eliminate noise and increase friction. However, some manufacturers recommend not using belt dressing."
I can do more research if your not yet convinced.
Or you can pass by Central Diesel for an actual.
February 16th, 2009 12:04 PM #27
Good morning 4JGtootsie!
That statement is correct. If you read between the lines, the article implies that there should be good friction between the belt and pulley, to the point of spraying belt dressing to increase friction. I agree with the manufacturers, however... use belt dressing as a last resort.
Anyway, this discussion has gone too far and off topic. I'll just leave you with my final word about it. It is my contention that drive belt slippage is not desirable. Where there's slip, there's power transmission loss.
Here are a couple of videos which shows this fact.
[ame="http://www.youtube.com/watch?v=NvLEnPeKj5o"]YouTube - Supercharged 2002 jetta vr6 belt Slip[/ame]
[ame="http://www.youtube.com/watch?v=LfDGBblXQ1A"]YouTube - 1994 paseo steering pump belt slippage[/ame]
February 16th, 2009 04:48 PM #28
Nice videos.
If you have a diesel vehicle (even gas), i am still inviting you sa shop at 1176 Quezon Avenue beside Capitol Medical so you can see what we do. Since we deal with fueling- timing marks, belts, chain, gears, cam position, crank position is of vital importance to us. Pakita ko rin how we calibrate common rail systems and other type of injection pumps. Hope to see you bro!
February 20th, 2009 04:17 PM #29
pano malaman kung original ang timing belt tsaka magkano po? para sa 98 lancer el ko po. TIA!
February 20th, 2009 05:05 PM #30
