Quote Originally Posted by Condotiere View Post
Guys I just wanna share a little DIY I just did. O overfilled my engine oil by about 300 ml and O didnt want to drain it via the drain plug in the oil pan and refill the oil. What I did was buy the biggest syringe i could find in the drug store, attach it to a clear plastic aquarium hose then inserted it into the oil dipstick hole then suck the oil with the syringe. Repeated process until O rwmived the rigjt ammount of oil. Easy, no need to crawl under your car!
Sent from my SM-N920S using Tapatalk
You can also quick change ATF, Power steering, and coolant this way.
But not for brake fluid
