Results 31 to 40 of 60
March 26th, 2015 12:26 PM #31
di kasi nila na-factor in yung other costs of ownership like maintenance, 2nd and 3rd year insurance, parking cost, and even the price of gasoline nung nag-decide sila bumili ng car.
Tsikot Member Rank 3
- Mar 2004
- 2,053
March 26th, 2015 01:14 PM #32I consider driving within Metro Manila as extreme driving.
75% of my daily drive to and from office is spent idling and creeping at < 10kph.
Kahit na low mileage, pinapa oil change ko na rin.
- Apr 2014
- 473
March 26th, 2015 01:46 PM #33My intention of asking this question is not because I cannot afford an oil change or maintenance costs. I'm after for value for my hard earned money. Di naman kasi pinupulot ang pera, unless magnanakaw yung tao.
If we are to change mineral oil every 6 months for low mileage cars, probably its a good thing. However, if we are to spend on expensive fully synthetic oils that are designed for extended drain intervals (E.g. 20,000km or more) what's the point of using them in if we are required to change oil every 6 months regardless of mileage?
Are we guided by myth or conventional knowledge, or do we have the science and facts for real answers?
- Dec 2008
- 462
March 26th, 2015 02:29 PM #34Find the thread remote bypass oil filtration. Everything is explained there.
March 26th, 2015 02:34 PM #35
My opinion on this is that the conditions in an engine is the same whether you use synthetic or conventional oils. The entire combustion process produces soot, metal wear due to friction all end up in oil. These needs to be flushed out regularly before it affects the engine components.
Now if your vehicle is seldomly used, it is a fact that oil degrades, minimizing its lubricating functions, maski na synthetic pa yan... well probably, the additives used in synthetic oils degrade + the actual oil itself degrades. now if you are really in doubt, i suggest you go for an oil analysis. FS oil, before pouring out, will not hold the same characteristics inside the engine.
second, is that oil gets contaminated after it is poured out from the package. the contaminants will not protect your engine if you are using a FS oil.
siguro para di ka na din manghinayang, use a semi-synth or regular mineral oil next time, which I do, dahil nothing beats peace of mind after going through engine breakdown dahil sa lengthy oil change interval.... FS oils for daily driven and non-modified cars for me would be too much dahil kumikita din dyan ang casa eh, so yan ang recommended nila.
now for the question on the point of using extended drain oils, i personally believe its marketing hype. kung FS gamit mo, the safest would be draining it at 10k kms, not at 20k kms.
imho.
imho.
- Oct 2009
- 2,271
March 26th, 2015 04:01 PM #36sa akin every day ko gamit las pinyas city to malate.araw araw gamit,tapos week ends uwi sa nueva ecija.
hindi inaabot ng 6months..5k palit nako ng oil..
minsan 4 months palang nakak 5k na ako..
March 26th, 2015 05:06 PM #37
bottomline is follow the recommended change interval by the manufacturer or the users manual and use the minimum oil specifications recommended para walang problema.
bottomline is follow the recommended change interval by the manufacturer or the users manual and use the minimum oil specifications recommended para walang problema. sometimes kasi, information on the internet messes things up.
- 52,731
March 26th, 2015 07:06 PM #39
March 26th, 2015 07:26 PM #40
If you want a definitive answer re: safe extended oil change intervals you'll have to pony up and pay for used oil analysis. Things to ask for in a UOA are TBN, TAN, fuel dilution, the amount of silicates and other contaminants as well as wear metals. Thing is, it's expensive and you have to get at least three UOA's in a row (with exactly the same oil) to establish a trend. Even after that there's no assurance that your engine will get the same results as it ages.
That's the reason why most people opt to err on the safe (and economical side) and change oil (mostly mineral or semi synth) at 5TKm. The type of engine also matters. If it's a modern turbocharged engine I wouldn't run mineral oil at all, no matter what the API rating.
I'm for the idea that oil change intervals should be based on the amount of fuel consumed, since the contaminants are combustion byproducts. Elapsed time between changes, mileage or running hours are factors as well, but IMO the amount of fuel consumed gives a more direct correlation to the amount of oil contamination.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
