Results 41 to 50 of 53
- Aug 2011
- 31
September 11th, 2011 05:19 PM #41It last 2 yrs. sa akin. '92 L300 vv gas/LPG.
Pero after ko mabasa ito, bumigay Ang capacitor 1000microF. Nag-ground yata sa body?!!
Talaga bang may current ang Heatsink??? Lakas eh. nabuhay lahat.:ooops:
Available pa rin sa Alexan.
I'm not expert on electronics, kaya pinagawa ko sa Alexan.
Pinakamahal na part ay MJ10015(P500+). Plus P150 labor. Wala ng Motorola.
Kahit saang Alexan puwede makuha after repair...
PERO! Ayaw nila gawin pag di intact ang parts.
FYI.
- Jul 2011
- 6
January 9th, 2012 03:44 PM #42Sir Lan0520,
Wala bang modifications ang Alexan sa E.I. Kit? Tinanggal ko kse ung sa akin kse d talaga kaya ng ignition coil ko..mayadong umiinit ang coil...
Tnx.
January 11th, 2012 02:07 PM #43
Dear Lan:
I am not familiar with the Alexan design.... can you post or e-mail that to me...
Most electronic capacitors have 2 wires + and -, therefore they are not supposed to be grounded.
The only ones that I know to be grounded are the condensers used in automotive applications + for the lead wire and - to the body ground
Dusky
- Nov 2009
- 21
January 12th, 2012 10:16 PM #44
January 13th, 2012 06:34 PM #45
Dear bongski:
Thanks for clearing that up.
It seems to me that there are a lot of problems using transistorized ignitions for standard coils - the heating issue.
I recommend that you use a very conservatively designed coil - like the old black Nippondenso's with the square ballast resistor.
Don't by-pass the resistor and check very carefully the dwell angle you're using, try to use the smallest practical dwell angel to keep the turn-on times shorter.
If the coil still heats up try using a higher ohm ballast resistor (available at Raon - just specify the amperage you want).
Using a a ballast resistor with higher ohm rating should control the current very effectively in the coil.
Hope this helps,
Dusky Lim
- 52,731
January 13th, 2012 07:52 PM #46we played around with transistorized ignition on our beetle many years ago. it worked fine. no bulutong on the contact points. easier starting. then one day, the engine died. no amount of coaxing re-started it. the culprit: dirty contact points. it seems, the hi voltage of the traditional kettering system also served to clean the contact points of dirt. when we installed transistorized ignition, the hi voltage that used to clean the points, was not there anymore. after some time, dirt built up and prevented the electrical contact from occuring. engine stalled. the solution was to simply clean the points at regular intervals. i guess that is why manufacturers shifted to optical or magnetic distributors..
- Jul 2010
- 570
January 17th, 2012 03:31 AM #47I'm building Multiple spark CDI and its already working. I installed it in my Lancer EL 1996 4g15. I still use the original Distributor with magnetic pickup sensor and built-in Ignition coil. THe CDI can produce 6 sparks at low rpm and gradually reduced spark as it the rpm increases. Ignition voltage on primary of ignition coil was 400V or equivalent of 40kv on the secondary of ignition coil.
But I'm encountering intermittent misfire and found out that high voltage noise was pickup by cdi trigger circuit and causing it to misfire. CDI was now again in my working table for modification of trigger circuit. Already made modification of the trigger circuit to isolate it from high voltage noise. Have to transfer new component to a small pcb.
Just to inform you that CDI will not cause overheating of Ignition coil. Because spark voltage was charge in Capacitor and not in the Ignition coil.
- Nov 2009
- 21
January 17th, 2012 06:23 PM #48Hope you've fixed that misfire on your cdi, i googled some schematics on multiple spark ignition before but found it hard to source out the parts here, might have been a good diy to tinker with on my lazy hours.
It seems that ignition coil is the sticking point on electronic ignition builds, but YMMV, i have used an old(got it used) Bosch red coil from day 1 I installed alexans kit, drove w/ it w/out the ballast resistor and never had a problem.
- Jul 2010
- 570
January 17th, 2012 09:59 PM #49I have a friend from Mitsulancer forum who also built the Alexan Electronic Ignition and ask for my assistance. I've able to make it work by replacing the NE555 ic.
Actually, the original schematic of the multiple spark cdi from the internet have a lot of problem. Aside from it very hard to source the main spare parts needed. I've able to make it work but encountered following problem..
1.The 22 khz inverter will stop if +dc supply was below 10V.
2. Power FET transistor will not last an hour and get shorted due to high current ( 6Amp ).
3. Intermittent misfire from high voltage noise.
I've solved problem 1 & 2 by modifying components ,circuit and almost 60% of original circuit. Now. my cdi consumes 0.8A at 800 rpm and 2.5A at high rpm.
I hope my new circuit for noise isolation circuit will correct the 3rd problem on actual test on my car or else i'll convert it to single spark to solve the problem.
- Oct 2013
- 4
October 24th, 2013 05:01 PM #50I still make them. Been making EIS for over 25 years. Old price P2,500 installed. 0922 296 6288 or Globe 09163068924. Bong
Automatic po Sir
