Results 1,051 to 1,060 of 1853
- Aug 2003
- 317
July 12th, 2013 03:43 PM #1051Bought powerburn at 126/L earlier sa gas station. Yes jaso FB same as caltex and shell's 2T.
- Feb 2013
- 157
July 12th, 2013 06:35 PM #1052Apologies if this has been answered and being such a simple question. Do you put 2T oil before, after filling up or it should be in-between? Or this doesn't matter?
Thanks!
July 12th, 2013 07:04 PM #1053
It doesn't matter, 2t concentration within the diesel in the tank will eventually even out. But if you want it to happen sooner, then add 2t first, then fill up.
I usually fill up first, go home and park, measure the right amount of 2t from a 1L bottle of petron 2t, then dump it in the tank.
- Feb 2013
- 157
July 15th, 2013 02:39 PM #1055
- Jul 2009
- 2
July 15th, 2013 03:09 PM #1056
not sure kung accurate pero naramdaman ko talaga yung difference..
yes some say na walang top speed, or performance na pagbabago pero chineck ko using OBDII scanner..
notice in the picture na naging 99 WHP siya after adding 2T.. ramdam after few KMS..
by the way.. ang oto ko ay Hyundai Tucson JM 2.0 CRDi Turbo Intercooled
- Jul 2011
- 584
July 16th, 2013 03:10 PM #1058
I just got my new 2013 Mitsubishi Strada GLX Non-VGT. Okay po ba maglagay ng 2T with this engine?
July 16th, 2013 05:54 PM #1059
Banas na banas ako sir buong byahe from manila to sbma at buong stay sa subic gaspang manakbo at bitin hatak parang hirap turbo diesel pa yun, then pauwi after magpakarga diesel max lang with powerburn 2T oohyeah ang dulas talaga kinis manakbo at adik bumirit sa sctex, pansin ko din bagal bumaba ng fuel gauge, posible talaga tumipid dahil ramdam mo ganda sa takbo at di hirap makina.
Sent from my ifive MINI 2 using Forum Runner
July 16th, 2013 05:58 PM #1060
I went with him at LTO's The Link satellite office nung nag-renew sya. We were given a number to...
