Results 31 to 40 of 1853
- Nov 2005
- 255
April 25th, 2011 03:38 PM #31
- Apr 2011
- 78
- Jan 2007
- 409
April 26th, 2011 10:01 AM #33Tried it on a 4d56. Not bad the smoothness is noticeable but no conclusions yet when it comes to performance or efficiency
April 26th, 2011 11:26 AM #35
I used whatever was cheapest, I could get Penzoil at he Duty free on Clark cheaper than any local brand like 67P for a 1 quart bottle, Could not find anything even close to that cheaper, got to love surplus.
Your not going to get any real differences between brands, so whatever fits the specs and your wallet is what you should get. Older diesel it's like night and day on how it smooths out the engine.
April 26th, 2011 11:37 AM #36
April 26th, 2011 11:42 AM #37
hehe, same experience here, ako naman dahilan ko e pang-linis ng exhaust since may decarnobizer yung Shell 2T.
Kaso FB lang siya, hanap pala me ng FC rating na 2T for an even cleaner burn. OCC or yung blow-by filter would really help in improving carnon deposits in our diesel rides talaga. Linis pa ng turbo and intercooler pipes.Fasten your seatbelt! Or else... Driven To Thrill!
April 26th, 2011 02:54 PM #38
Hi Guyz,
Pajero '92 4d56 owner here. I got interested with this topic as i was browsing. Is it ok for me to use this? My rig is use daily as a service and want to assure if this 2t-diesel combi in our engines is safe for what i know is we can only put diesel as our fuel.
And can some enumerate the pros and cons of using 2t oil in our diesel engine?
Likewise, what are the steps in putting 2t in our diesel tanks?
Please advice,
More power
OT: Can i use cherry scent 2t?
- Jan 2007
- 409
April 26th, 2011 07:12 PM #39
April 26th, 2011 08:19 PM #40
The mix ratio has been stated several times it's 200:1 or 18ml per liter or about a once for every 4 liters.
Diesels can burn almost anything oil based, the 2t oil mixes evenly with diesel fuel. The simpliest way I can put it is all you are doing is adding a lubricating agent to your standard fuel. It makes it equivilant of running biodiesel. It lubricates your injector pump making it last longer and your keeps your nozzles cleaner.
It's been in use for years and years and has millions of vehicle miles tested on it. No down sides when mixed at the proper ratio.
Remember you can burn 100% used cooking oil biodiesel in your diesel and it will run perfect.
You just unregister the device where its currently installed.
National ID Law
