Results 21 to 30 of 1853
April 21st, 2011 08:06 PM #22
Yes it is, Some 2007 and up U.S and European models that are ULSD complaint cannot use it, None of the vehicles there that I know of fall into that group.
Just follow the correct mixing ratios. Injection pumps are expensive to replace, best to take care of them. Also using bio-diesel is a big help.
- Jul 2008
- 935
April 21st, 2011 08:11 PM #23[SIZE="4"]
Yap, that's right...Coz in 2-stroke motorcycles you would see some carbon deposits on the exhaust pipe which hardens in time...It looks like a hard charcoal...I'm worried that it might accumulate in the pipe and it's gonna be really difficult to remove...Have you ever experienced that?[/SIZE]
- Nov 2009
- 3,482
April 21st, 2011 08:49 PM #24From what i understand, carbon deposits in the form of burned oil in 2-stroke motor is due to incomplete combustion. Comparing that to 4-stroke motor, you could seldom see any gunk in the pipe.
- Jan 2007
- 409
April 21st, 2011 08:51 PM #25
April 21st, 2011 11:42 PM #26
seems there are definitely a lot of upsides in adding 2T, will try it out on my rig.
though I have read somewhere that you may risk leaky injectors? has anyone experienced this with long term use of 2T?
April 21st, 2011 11:47 PM #27
- Dec 2003
- 137
April 23rd, 2011 09:54 AM #28Stumbled upon this as I was reading up on the topic.
http://www.4x4community.co.za/forum/...ad.php?t=40981
Last few pages is where it gets interesting. Same scenario as we have here. Problem is not really the lack of lubricity of ULSD as I don't think even the boutique diesels of Shell and Petron are even LSD - it's the quality of diesel and the presence of water, "extenders", and dirt.
Will definitely try 2T on my next fill-up.
April 23rd, 2011 11:12 AM #29
A good high quality fuel filter with water separator also helps out a lot. OEM is not going to cut it for anything smaller than 40 microns. If your out of the oppressive warranty get a Donaldson, Fleetguard or Baldwin replacement, They are all around 95% to 97% efficient at 20 microns efficiency and filter down to 5 to 2 microns absolute which is about 4 times better than any OEM fuel filter.
If you don't mind the big pieces of grit going through your injection pump and nozzle stick with OEM Not to mention they are cheaper than OEM. With the fuel quality there 25K is what I will keeping my fuel filter changes at.Last edited by dvldoc; April 23rd, 2011 at 11:26 AM.
April 25th, 2011 03:23 PM #30
Been using 2T since February 2010 on my 93 patrol safari.
I first read this in australian forums, they are using mineral based 2T as additive to diesel to compensate the ULSD. Tried it myself and to my surprise, their claim was indeed true.
My engine runs smoother, more quiet than with out 2T. After filling up using the 1:200 ratio it took a few kilometers driving before I felt the effect. But after that it was really day and night!
I thought it was placebo so I tried not using 2T. Then after a while my engine was back to where it was before I used 2T. Noisier, that sounds like 10 small people hammering the engine block...
So now I'm a believer 2T is good! BTW my exhaust does not give out smoke even at high speed. Though I do not look at the emmissions result.
Problema lang sa pag karga ng 2T mas matagal magpa karga sa gas stations! Ayaw lagyan ng gas boys eh kasi pang motor daw yun! haha! nagpapa alam pa sa kung sinong supervisor kahit sinabi ko na na ikarga ang 2T sa tanke bago kargahan ng diesel :D
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
