Results 2,261 to 2,270 of 2348
- Jul 2016
- 939
July 16th, 2016 06:32 PM #2261Have your ecu scanned. Baka may pending fault na. Test drive nyo and check all the signal from the sensors. Yun lang mahirap na part, ung magaling na technician na naiintindihan ung mga values ng sensor. Alam ung low/high and normal. Ung iba kasi merong 30k pesos worth of scanner pero ang alam lang gawin is tignan kung may lalabas na fault code. Di sanay mag interpret ng data.
- Jul 2016
- 939
July 16th, 2016 06:37 PM #2262
- Apr 2008
- 6,237
August 8th, 2016 01:53 AM #2263Sir Dieseldude, We've recently procured a Granvia with a 1KZ engine. So far engine pulls well, but fuel efficiency leaves something to be desired, even after oil and filter change. I'm thinking if cleaning/blanking the EGR will improve things. If it does, around how much does it cost?
Sent from my SM-G900I using Tapatalk
August 23rd, 2016 11:40 AM #2264
sir dieseldude,
have you tried swapping injection pump na mechanical, ikabit sa isuzu 4JH1? due for calibration ang pump ko, 65k ang estimate. nabasa ko sa net na may nakapagkabit na ng mechanical na IP. mula sa 4JB1 at 4JA1 papuntang 4JH1. id rather go for swap than have the anxiety on electronic fuel pump. if the cost are the same, im inclined on mechanical pump. any suggestions sir?
- Dec 2013
- 677
August 23rd, 2016 12:17 PM #2265Magkano normally inaabot ang calibration ng fuel pump 4ja1? Kahit ballpark figure lang para d maloko...thanks!
Sent from my LG-D855 using Tapatalk
- Sep 2008
- 587
August 23rd, 2016 02:00 PM #2266dieseldude, do you advise on using fuel injector cleaners? There is actually nothing wrong with the car, I was just wondering if it will be good for the injectors, if yes, what fuel injector cleaner do you recommend?
- Oct 2014
- 162
September 11th, 2016 10:50 PM #2267
- Sep 2016
- 7
September 11th, 2016 11:40 PM #2268good day to everyone. mga sirs, i hope you can help me with my headache. my car, a manual transmission diesel toyota innova 2014, as i have observed, lost some speed or power. i dont know which is which (speed or power). explanation: 3 months ago, it used to give me a good speed at 2,000 rpm.
at gear 1 it gives me 20km/h
gear 2 --> 40km/h
gear 3 --> 60k/h
gear 4 --> 80km/h
but now it gives me lesser speed for the same RPM (2,000rpm)
gear 1 gives me 16km/h
gear 2 --> 34km/h
gear 3 --> 54 k/h or less
gear 4 --> 80km/h
gear 5 --> 90km/h
in short, there is around 20-25percent speed reduction or power reduction regardless of the RPM (either 2,000 or 3,000rpm). i dont know which is which. i have asked mechanics and they gave me different suggestions - all of which never rectified the problem.
oil change
gear oil change
fuel additives
engine air filter
engine oil filter
fuel filter
all done but the problem still persist. can you please enlighten me on what could be the problem?
thanks in advance po sa sinumang sasagot at talagang masakit sa ulo isipin.
- Apr 2009
- 536
September 27th, 2016 07:25 PM #2269Hi Everyone,
Ask ko lang po kung may naka experience at ano ang possible problem. We have a company
delivery van Isuzu elf 4jb1 mileage 200k. the injection pump already calibrated. the problem is
if on idling for 15 to 20 minutes engine will shut down, sa restart you have to pump the sedimentor pump
to start the engine. it seems nauubusan ng fuel going to the injection pump. But if choke knob is adjusted to higher rpm ( 750rpm) it will be fine.
yung low idling like niya nasa 500rpm lang after 15 to 20min mamatay engine.
thank you
- Oct 2016
- 2
October 12th, 2016 05:03 PM #2270
