Results 1,241 to 1,250 of 2348
January 13th, 2011 06:13 PM #1241
- Sep 2006
- 1,335
January 14th, 2011 09:31 AM #1242
- Sep 2006
- 1,335
- Jan 2011
- 6
January 14th, 2011 09:50 AM #1244hi, i have a nissan datsun td23 pickup, last year hindi na register ng brother ko it failed the emission test. recently, i had the nozzles cleaned, timed the injection pump, clean the air filter and still have black smoke. the guys at the calibration center said that because its nissan maitim usok nyan. tama ba to? ano pa ba pwede gawin para maipasa sa emission? (the mechanic recomended that we choke the pump on the day na mag pa emission.) but i want to do it legally clean para pagpalain tayo ni Lord. help...
January 14th, 2011 12:22 PM #1245
Sorry for insufficient info, my car is crosswind 2003, 150k mileage niya.
Bought it from the first owner, sabi niya casa maintain and may record naman nga kasama noong kinuha ko.This my first owned diesel car kaya hidi ko pa masyado alam kung ano mga dapat tandaan at gawin.
Isa lang Isuzu casa sa Batangas, anybody here can confirm that Isuzu San Tomas is not that good. kaya tuloy sa Rapide ko nadala although nababasa ko dito na SOP nila hindi ganun kaayos.
January 14th, 2011 12:39 PM #1246
- Nov 2002
- 179
January 14th, 2011 05:00 PM #1247
- Sep 2006
- 1,335
January 14th, 2011 09:42 PM #1248hi, i have a nissan datsun td23 pickup, last year hindi na register ng brother ko it failed the emission test. recently, i had the nozzles cleaned, timed the injection pump, clean the air filter and still have black smoke. the guys at the calibration center said that because its nissan maitim usok nyan. tama ba to?
That's not true. This is a clean burning engine, but emits more smoke than the newer engine models. A little black smoke is normal as long as it passes emission test.
You are doing the right thing. I have seen a lot of cars fail emission test. But when we tested it, the car was actually passing. This means that the testor may just want some under the table money for him to pass an already passing vehicle.
- Sep 2006
- 1,335
January 14th, 2011 09:53 PM #1249To do a good compression test, the workshop should have an accurate compression gauge, know Isuzu's recommended procedure for conducting this test, and also have the reference minimum pressure values.
I recommend doing the test on a cold engine, before starting it in the morning.
- Aug 2009
- 1
January 15th, 2011 12:48 AM #1250sir dieseldude newbie po ako sa diesel... ask ko lang po sana advice niyo regarding our XUV 2004 crosswind M/T. napansin ko po kci na parang kumadkot yun sasakayan at a speed of 60-80km... ano po kaya ang problema nun? nasa 46km mileage pa lang po yun crosswind namin. ano po pala gamit nun water separator? kelan po ba dapat dinadrain yun?
thanks in advance...
