Results 2,331 to 2,340 of 2348
- Oct 2018
- 12
November 2nd, 2018 07:51 PM #2331
- Nov 2009
- 3,482
November 2nd, 2018 08:11 PM #2332iLan na odometer, na overhaul na? Try mo pa compression test or check injection pump. Ang diesel(compression ignition) kpag hard starting pwede loose compression. Ang gaso(spark ignition) kahit agnas na yung piston ring aandar parin pero maingay at mausok.
November 6th, 2018 12:42 PM #2333
maari din na front oil seal ng injection pump.....tanggalin mo upper timing cover at inspect ang sprocket area ng injection pump.
November 6th, 2018 12:47 PM #2334
Can anyone recommend a shop that does compression testing? Central only does it via OBD2.
- Oct 2018
- 12
- Feb 2019
- 3
April 10th, 2019 01:37 PM #2336Hello, need help po. I have toyota 2l diesel, ilang days na din di umaandar. Relaced battery kse bumubula n pero ayaw pa din. Gumgna starter pero mukhang walang diesel n pumpasok so i tried cleanibg the fuel injectors. Found lots of carbon. After cleaning, ayaw pa din sya mag start. Some say sa manual pump bka may hangin. Btw walang nlabas na usok after cranking. Any idea po. TIA
- Jul 2006
- 3
June 19th, 2019 10:42 AM #2337
- Jul 2019
- 2
July 9th, 2019 10:54 AM #2338*Sir Dieseldude
San po shop nio sir? Pa-check ko po sana yung pick-up ko (nissan eagle) regarding sa white smoke sa exhaust tip
- Dec 2019
- 1
December 19th, 2019 10:04 AM #2339Hi sir, question lng po and medyo newbie here when it comes to diesel cars. ok lang ba itest ung fuel injector ng pick up ng friend ko sa suv ko. same brand? salamat po sa maglilinaw
December 19th, 2019 11:48 PM #2340
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
