Page 62 of 118 FirstFirst ... 125258596061626364656672112 ... LastLast
Results 1,221 to 1,240 of 2351
    #1221
    Quote Originally Posted by izzy06 View Post
    ingat lang po sa pag-gamit ng oil catch can dami na kasi akong nabasa nasira ang engine dahil dito, gusto ko rin sana lagyan ang frontier ko kaso nagbago na ang isip ko nung nakabasa ako ng mga negative results ng oil catch.
    sir ano yung mga negative results na nakita ninyo?
    #1222
    di ko na matandaan sir pero google mo na lang madami kang mababasa may positive at negative results pero dun na ako sa medyo safe kaya di ako gagamit ng oil catch, malay natin yung ibang nakaranas ng di maganda di na lang nagpost ng experience nila sa oil catch can.
    Jan 2011
    #1223
    dieseldude narhhhirapan n po kc humatak yung adventure diesel 2003 mdl ko kakachange ko lng nman. nilinis ko n yung filter s makina pati fuel filter nilinis ko n rin pati air filter nilinis ko n rin. pag nag accelerate k parang puro gas lng parang nahihirapan yung makina.
    tnx in advance....
    bka kc may kinalaman n s fuel injection eh...
    Sep 2006
    #1224
    Quote Originally Posted by ayenolasco View Post
    tnx in advance....
    Possible injection pump problem.
    Pero, replace fuel filter muna......... di naman mahal yan.
    Apr 2005
    #1225
    good day sir jake,
    need your usual help here.my nissan urvan homy td27 turbo engine unit suddenly emits white smoke.first time na nangyari so itinigil ng driver ko yun van then pinatay na nya ang engine.hinatak na lang namin pauwi ng garage to prevent big damages.then my i was instructed by one mechanic na ipacheck ko yung injection pump coz of possible injector issue.
    injection pump was pull down,and clean and calibrated.nozzle was also check and clean.still when we test meron pa din white smoke.
    the van had no overheat before nag emit ng white smoke,and very minimal ang oil consumption,ok naman ang andar ng engine at one click pag start.
    thanks,
    nitram
    Apr 2005
    #1226
    good day sir jake,
    need your usual help here.my nissan urvan homy td27 turbo engine unit suddenly emits white smoke.first time na nangyari so itinigil ng driver ko yun van then pinatay na nya ang engine.hinatak na lang namin pauwi ng garage to prevent big damages.then i was instructed by one mechanic na ipacheck ko yung injection pump coz of possible injector issue.
    thanks,
    nitram
    Apr 2005
    #1227
    Sorry po..Double post
    Quote Originally Posted by nitram View Post
    good day sir jake,
    thanks,
    nitram
    Sep 2006
    #1228
    Turbo could be leaking oil.
    #1229
    sir diesel dude,
    i blew a cylinder head gasket. found oil in my radiator and my engine oil dipstick's color is gray.
    should i overhaul the injection pump as well since its lubricant is contaminated with the engine's oil/water mixture as well?
    thanks!
    Sep 2006
    #1230
    Quote Originally Posted by chase View Post
    sir diesel dude,
    thanks!
    Pump overhaul is not really necessary.
    Btw, what is your engine?
    #1231
    need info sir, ilan ba injector nozzle ng 4jg2? how much would it cost ,just to have an idea.. thanks..
    Jun 2008
    #1232
    Quote Originally Posted by gioravelo15 View Post
    sir mejo OT lang useful ba ang oil catch can for our 4M40? what are the advantages and disadvantages of using this?
    Sir this is what happen to my intercooler with out catch can ........but i would like to remind you i run my engine hard on road and offroad.
    Oils is visible inside the intercooler making it inefficient in cooling down the compress air and found a sticky gunk in the pipes................oil catch can will prevent this to happen and our inter cooler should not have oil inside. I havent heard any problem resulting from using an oil catch can and im using one on my truck too.
    Sep 2010
    #1233
    Sorry pero hindi ko alam kung pumasok pero 3X ko na sinulat ito, Kapag ba start sa umaga or kahit sa hapon basta matagal na tigil ang sasakyan tapos may white smoke indication na ba ito ng poor compression? Na-confused kasi ako sa sinabi ni Sir DD
    #1234
    Quote Originally Posted by Dieseldude View Post
    engine is a daewoo dc24.
    checked out the cylinder head, may leak daw. will try to bring it to a more reputable shop for repair.
    is it advisable to repair a cylinder head?
    Sep 2006
    #1235
    Leaks are most often due to a blown/burnt head gasket.
    Warps are easy to repair through deck resurfacing. Cracks are difficult. Ask the machine shop for warranty if they will perform a crack repair.
    Sep 2006
    #1236
    Quote Originally Posted by El batangueno View Post
    Possible poor compression ito. Hard starting din ba?
    Magpa compression test ka para makasigurado.
    Marami pang dahilan ang white smoke...
    Sep 2006
    #1237
    Great pictures.
    Small amounts of oil in the intercooler is normal.
    Sep 2006
    #1238
    Quote Originally Posted by henriboy View Post
    Ilan cylinders ba ang engine mo? Yan din ang bilang ng nozzles.
    #1239
    4 cylinders po, thanks... any idea on how much per piece cost?
    Sep 2010
    #1240
    Possible poor compression ito. Hard starting din ba? One click lang po kahit nga ata two week siya hindi nagagamit
    Magpa compression test ka para makasigurado. Saan po ba kayo may marecommend dito banda south luzon particularly Lipa city.
    Just for info lang sir DD, my car is XUV 2003 MT and still can run up to 150kph at 450rpm and fuel consumtion is ave of 13km/lit sometimes 15 if more on hi-way. Worry ko lang po baka kapag pina compression test ko eh tapos hindi ba pala competent yon gagawa kung ano pa mangyari.
    Thank you sir and other forumer here for being generous giving your knowledge!
Diesel Fuel Injection System Help Desk
