Dieseldude,
one more time.
my battery just gave up this afternoon....i jumpstarted it using a battery from a nearby batt shop...upon starting, white smoke came out and after a few acceleration there's still white smoke but on the way home it was black again during sudden acceleration.... Check injection pump timing....
I found out that the solenoid connection is loose...had some checks with the batt shop using a meter....batt shop said nothings wrong with starter (probably), alternator and battery..problem is with the wirings. Check battery cables, grounds and positive main connectors.
ang palaisipan e bakit ngayon lang nangyari e matagal nang lazy starting ang engine...with regards sa short-to-grounds, mabagal na trabaho ito kung meron man...
plus i've read from a foreign forum that timing retard also causes turbo lag...mejo may koneksyon ito sa problema ko kasi nga di ko na marinig sipol ng turbo kapag acceleration. Baka maayos lahat yan pag na-time nang tama ang pump....
kindly enlighten me sir. TIA
