Quote Originally Posted by RedCoder1 View Post
Hi Sir Dieseldude,
My ride is a JDM Pajero, 4d56 TDIC engine and A/T.
Problem is when I go on a full stop, o kahit slow down lang na almost stop na, parang nasasakal/nabubulunan yung makina. Kahit anong rev mo ayaw umusad. Maghihintay ka ng mga 3-4 seconds bago mo maramdaman na magaan na ulit sya saka ako aapak ulit sa accelerator tapos aandar na sya. Di naman namamatay ang makina. Ramdam ko din na kahit nasa D ang A/T setting pag binitawan mo yung accelerator habang umaandar parang nakaapak ako slightly sa brake.
Dinala ko sya sa isang shop this weekend. Ang ginawa nila to test ni-rev ng ni-rev ang makina while A/T is at P. Sabi baka calibration kailangan kaya lang ang laki ng quote kaya di ko pinaayos. Pag-alis ko sa shop pakiramdam ko mas nakahinga makina. Di na lumalabas yung problema pag slow down lang pero pag full stop ganun pa din. Somehow, I guess, nakatulong yung pag-rev nila paulit ulit ng todo sa makina.
Air filter is two weeks old, changed fuel filter January this year, change oil and oil filter last month.
What could be the problem here, sir?
Salamat po.
HI! I hope you and Dieseldude doesn't mind. Your fuel filter has been changed last January so it must be needing replacement already. Even if you seldomly use your vehicle like me, I think you should have reached 5000km of travel already since January. It is recommended for diesel engine fuel filters to be changed every 5000km. I hope this will help you in addressing your concerns.
