Results 11 to 18 of 18
December 23rd, 2003 11:14 AM #11
PROMDIBOY, oo nga, pansin ko rin yan with Fuel INjected engines... kakastart mo pa lang rev agad sila.
December 23rd, 2003 11:52 AM #12
Natatangal yon di ba? Yung idle up nakakabit sa temp sensor? Para di mag high rev?
December 24th, 2003 05:27 AM #13
yung nissan sentra GT namin ganun, lakas mag rev pag every start. i find no problem naman? sorry OT
December 24th, 2003 01:52 PM #14
pag uminit ba ok na ang idling?
if yes, your idler up switch and vacuum is at fault or your glow plugs. vacuum and idler up step lifts your rpm pass the normal (mainit) idling when your engine is cold to prevent vibrations. glow plug preheats your combustion chamber for easy starting from a cold start.
if no, then namamatayan (no idling), its' your solenoids usually located in your injection pump. or it might be the electricals. one dead cylinder could also be the culprit.
it is not advisable to remove/disable the idler switch. doing so will delay the engine from reaching its operating temperature leading to hesistation, vibration, poor oil circulation and fuel economy. did you know that the your car airconditioning system particularly the compressor is connected to this idler up switch?
- Jul 2003
- 63
December 26th, 2003 03:55 PM #16I've had that same experience with a B2200. I checked the glow plugs, air intake filter and had the nozzles checked and changed fuel filter ok naman lahat. The culprit...................yung fuel line ko barado!!!!! Overtime kasi diesel deposits clog the fuel line. Have it checked.
December 26th, 2003 04:06 PM #17
Yung 4d56 may inline fuel strainer sa fuel line. DIY lang ang paglilinis. Pero hindi ko talaga matutunan. hehehehe.
December 28th, 2003 03:57 PM #18
hey guys, thanks sa suggestions. i'll have it checked immediately.
nga pala... afrasay, yup! after starting ok naman na yun idling nya... yun sa pagstart lang talaga hirap.
